Originally Posted by Captain Neo
There can be only two problems either in your RAM or in PSU Try to boot your system without ram and then again insert the ram.
Might be of help.
will my pc boot w/o ram....
wat will happen if i do dat??? i m sure its not a ram problem..
AFAIK ram cud not cause this type of problem which i m facing
Originally Posted by raj6789
the problem ur facing is of ur hard disk & ur power supply unit.
No
its not a Harddisk problem...harddisk problem has some other symptoms..
Originally Posted by smile
why do u want to repair ur PSU .....u can get it for 400 Rs. a new one
dats a nice cheap price r u sure will i get it @ dat price...bcoz i have a branded pc
& my friend told 2 get a new one u have 2 contact ur manufacturer
Btw: I m planing 2 upgrade my whole cabinet in 2009...so cant invest more bucks
now on this crappy machine...but have 2 resolve this problem....
will buy it if its available under Rs400....Btw which brand is dat???
