Old 16-06-2008, 09:52 AM   #1 (permalink)
Default Sound is frustating
Friends when i run my system it makes sound it may be fan sound even when i go for standby or hibernate my system makes sound. From the very first day i bought system(6 months back) it is making sound, my friends told it is normal since it is dual core.
The sound is frustating me.
Configuration :
Ram :512MB
HD : 80GB
Motherboard : MSI
processor : intel pentium D
Virus Guy is offline
Old 18-06-2008, 01:00 AM   #2 (permalink)
Lets Do It!
amrawtanshx's Avatar
Default Re: Sound is frustating
It will make sound cause ur fans are working.
In standby ...The comp. isn't totally off ....So to maintain the Temperature, fans work.
So no reason to worry.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 18-06-2008, 01:24 AM   #3 (permalink)
RexRazr's Avatar
sometimes the system do get turned off in stand by mode (fans stop working as well)...it depends on the type of the motherboard i think
my previous pentium based system's cpu fan used to make a lot of sound too sometimes...while booting up mostly...just like the heavy pick up of a sports car lolz...but the system had no flaws...one of my friend's system has the same noise still
i don't think it's much to worry about...
AMD X2 6000+@3.2GHz | XFX nForce 8200 HybridSLI | 4 GB 800 MHz DDR2 | XFX 8800 GT 512 Alpha Dog XXX | Seagate 320 GB Barracuda + Hitachi 250 GB DeskStar | Cooler Master Extreme Power Duo 600 Watts
RexRazr is offline
Old 18-06-2008, 03:04 PM   #4 (permalink)
Violent serenity.
Psychosocial's Avatar
nuthing to worry abt, its just the fans.
Psychosocial is offline
Old 18-06-2008, 10:05 PM   #5 (permalink)
smile's Avatar
Wink Re: Sound is frustating
Hm.......... check whether any wires are not touching fan ..if not then its alright
SR
smile is offline
Old 18-06-2008, 11:22 PM   #6 (permalink)
Yes it should be fine..
but just do check that if you have installed a cabinet fan, it is running at good speed. In my case my cabinet fan was making more noise because it was not spinning at good and steady speed. Note that here I am just refering to the cabinet fan.
I guess these days you do get systems wherein the CPU fan speed gets adjusted as per CPU temp.
patkim is offline
Old 19-06-2008, 12:47 AM   #7 (permalink)
dOm1naTOr's Avatar
The fan noise might increase with the amount of dust in it. Use a vacuum cleaner's blower to blow off the dust. So the fan can push same amount of air with less stress and speed, so noise ll be reduced dramatically.
Also it ll make real noise if the fan bearing is not aligned. If its a cabby fan, then get another one for 50 bucks. In case of proccy fans then see if ur mobo supports any CPU fan control utility like Q-fan[Asus mobos]. It ll regulate fan speed in accordance with CPU temps and concentrate on keeping the noise low.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 19-06-2008, 01:00 AM   #8 (permalink)
Alpha Geek Banned
bikdel's Avatar
Guys he's sayin sound comes even when system hibernates. That aint possible!
I'm not a GEEk, i still use Windows!
bikdel is offline
Old 19-06-2008, 01:02 AM   #9 (permalink)
dOm1naTOr's Avatar
maybe its some insect thats makin the noise
or the speakers might be hizzing.
G3: XPS M1530 |
FZ 16.
Old 19-06-2008, 01:24 AM   #10 (permalink)
Alpha Geek Banned
bikdel's Avatar
^^ lolz. You are funnier than NewsBytes.
bikdel is offline
Frustating problem help needed.....any1 there..... fun_theorem Software Q&A 2 28-07-2007 05:14 PM
Hissing Sound/Disturbance Coming From Speakers/Sound Card ! mikeon Audio 8 15-10-2006 10:37 AM
Frustating Half Life 2 experience gtoX Gamerz 1 20-10-2005 12:48 AM
