Hi guys:
This is going to be my first rig that I am going to overclock. I intend to get the cpu to run around 3Ghz without heavy investment in cooling. I want to spend as little as possible and get the maximum performance out of it. I rarely play games so I am looking at integrated graphics, main uses would be:
Lot of internet surfing, movies, music, and data storage
I only need the tower. After some research, I narrowed my choice down to two options:
1 Intel Dual Core 2.0 GHz E 2180 - 800 FSB/1MBCache Rs 3000
2 Athlon 64 X2 5000+ (Black Edition) without heatsink and fan Rs 4500
Irrespective of which platform I go with the following components will not change.
Transcend 2 Gb DDR2 800 Rs 2000
ATX cabinet with SMPS 450w Rs 2000
250Gb SATA HDD Rs 2000
+/- DVD RW Rs 1400
I intend to use an external hard drive with eSATA and USB interface, do I need to increase my power supply? And also suggest any good External HDD cases with eSATA and USB interface. I intend to use a 300Gb HDD with it.
As I intend to overclock, by how much do I need to increase the power supply? In my research I found out that AMD 5000+ can be overclocked up to 3Ghz without changing the stock voltage. What about the E2180? Please suggest what sort of cooling will I need?
Now coming to the mother board, this is where I am stuck.
I first decided to go with the Athlon 64 X2 5000+ (Black Edition) as the reviews were impressive and pairing it with the Gigabyte GA-MA78GM-S2H AMD 780G and SB700 Chipset Motherboard (Rs 4500), I would get everything I want.
But my mate suggested cheaper E2180 which would give me 3Ghz but I am unable to find a good mobo for it with similar specification as in the Gigabyte GA-MA78GM-S2H. I mean with HDMI, DirectX 10, good IGP, eSATA port etc.
If I get the AMD combo, I am sure I will not have to upgrade for at least for next 3 yrs. I would really like to get your opinion on E2180 setup. I would like to save further if I can. I liked what I read about overclocking E2180, but I am unable to find a good mobo with integrated graphics for Rs 4500 for E2180.
Finally, I am trying to get the whole package for Rs 17000.I would be very happy if I can get it down with E2180 combo. I only need 4SATA ports, I for eSATA and the rest for internal use, and a good IGP. I really don’t need HDMI, DirectX10 ( Do I need it?). how are Palit N73PV motherboards, they are retailing for Rs 3000.
Please let me know your thoughts and suggestions.
Thank you.
