Old 15-06-2008, 03:21 AM   #1 (permalink)
Default Monitor Disabled !!!
hi guys...
m struck in a big mess....
actually i have selected the option "do not use this device" under the monitor driver options.....
now as soon as i boot windows......my monitor goes off...
i can't even c the desktop screen for a second....
dunt know how to undo it....
pls help.... !!!!
amancoolguy777 is offline
Old 16-06-2008, 09:37 PM   #2 (permalink)
dhanusaud's Avatar
Default Re: Monitor Disabled !!!
OS?
If XP, before windows loading appears press F8 & then select ''ENABLE VGA MODE'' & press enter key.
See if it works.
dhanusaud is offline
Old 16-06-2008, 09:42 PM   #3 (permalink)
Intel OCer
amitash's Avatar
pop in xp disk and try repairing
My site: collegeclassroom.org
amitash is offline
Old 17-06-2008, 12:34 AM   #4 (permalink)
I don't think a repair will work but try the VGA mode and see if you can get into safe mode..... Sounds real wierd though. Maybe you can boot into another OS using a live disc and reconfigure - I've no idea how - sorry.
Kush6 is offline
Old 21-06-2008, 01:32 AM   #5 (permalink)
thnks 4 rplies guys....
bt i guess nothng seem 2 work....
format hi krna padega.,....
yes i ws using XP.....
neways....
thnx a tonn !!!
Old 22-06-2008, 12:57 AM   #6 (permalink)
If you haven't already formatted,you can try this for a last attempt.
Let the pc boot up properly.
Hold down the windows key along with 'R' to get the run prompt.
Carefully type in "control desk.cpl,,3" without the quotes(note the double commas) and hit enter.This will bring up the display properties applet with the 'settings' tab selected.
From here you have to tab your way into the monitor section.
Carefully follow the sequence...
hit tab 3 times(you're in the 'advanced' button)
hit enter (now in the page which has the monitor section)
hit tab 5 times
hit left arrow key 2 times(now you're right in the monitor section)
hit tab
hit enter
hit tab
hit up arrow key once (your monitor is back on!)
hit tab
hit enter
hit tab 3 times
hit enter
hit tab
hit enter
Done...
Maybe this sequence is different with diff systems but in the 2 I tried they were the same.
Let there be music.....
sashijoseph is offline
Taskmanager is disabled ashfahan Software Q&A 2 24-05-2008 08:23 PM
CD drive disabled !!! ravidawar QnA (read only) 10 22-04-2008 01:05 PM
USB Port are disabled. Itz_Me!!! Hardware Q&A 5 15-02-2008 08:30 PM
USB Drive disabled JBP Hardware Q&A 2 07-06-2007 03:09 PM
services that can be disabled? xp legolas Software Q&A 1 23-10-2005 03:49 PM
