Old 13-06-2008, 01:08 PM   #1 (permalink)
Pro Geeks
Micheal's Avatar
Default Looking to buy a Mid-Range Laptop...Help me guys
I need a laptop with these things:
1> Centrino proccy or Core2Duo proccy
2> widescreen (4 movie watching)
3> Robust build quality
4> Bluetooth 2, WLAN(or WiFi)
5> Integrated Camera (optional)
6> minimum 1GB DDR2 RAM @ 667Mhz or higher
7> DVD writer
8> Windows Vista Home Premium capable
9> standard HDD available today (I mean 160GB higher and good rpm too)
10>I need a decent(future proof) chipset but not if makes the price sky high
11> If possible a good graphics solution
Do post your comments and let me know
Micheal
Status: Digitized since 2004
Micheal is offline
Old 13-06-2008, 04:16 PM   #2 (permalink)
Alpha Geek Banned
bikdel's Avatar
Default Re: Looking to buy a Mid-Range Laptop...Help me guys
^^ Budget??
I'm not a GEEk, i still use Windows!
bikdel is offline
Old 13-06-2008, 04:32 PM   #3 (permalink)
Pro Geeks
Micheal's Avatar
wooopsy how cud i forget ???
BUDGET: 40K - 45K in all
Micheal
Micheal is offline
Old 13-06-2008, 05:08 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Dell 1525 or XPS are the best
Go for them and make sure tyou get 8600GT in the laptop
desiibond is offline
Old 14-06-2008, 12:08 AM   #5 (permalink)
Pro Geeks
Micheal's Avatar
yeah i checked out those models. only two fit my budget.
nemore suggestions ????
Micheal
Micheal is offline
Old 14-06-2008, 10:26 AM   #6 (permalink)
Self Confessed Geek
Dell fits your bill perfectly and all its models can be customized to your needs, anyway you want.
Visit Dell.com and choose India, scan though the Inspiron Series, 1420, 1525, 1720. First two numbers representing Screen Sizes.
You can get all you mentioned in every model above and further customize it, its very transparent.
Vaio will be too expensive and i personally dont like HP. I'll vouch for DELL only, I have one which is 3 years old and is running perfectly fine, i've ordered a new Inspiron 1420 also.
Last edited by vaibhav.Kanwal; 14-06-2008 at 10:28 AM. Reason: Automerged Doublepost
vaibhav.Kanwal is offline
Old 14-06-2008, 11:05 AM   #7 (permalink)
Alpha Geek Banned
bikdel's Avatar
^^ do u get a 1720 in that price range?
bikdel is offline
Old 14-06-2008, 11:19 AM   #8 (permalink)
Self Confessed Geek
1720 will cost on the higher side, i suggest 1420 and 1525 will suit or budget fine, and if you want to make it future proof, i suggest you go for 2GB Ram and T750 processor, Graphics card X300 will be sufficient enough for you needs and ocassional gaming too.
It'll cost you anywhere between 44000 and 50000 if the configuration is of the above order.
Dell USA offers discount coupons but these aren't available for Dell India.
Here's the link, check out the options you have, but all the prices are excluding Tax.
http://www1.ap.dell.com/content/prod...hs1&l=en&s=dhs
Old 14-06-2008, 12:30 PM   #9 (permalink)
Pro Geeks
Micheal's Avatar
thnx vaibhav.Kanwal and bikdel for ur valuable suggestions
i'm going to enquire now and let u no wen i have placed the order
BTW is it true dat u hav to directly place the order to the company and not ne vendor for any Dell products??
Micheal
Micheal is offline
Old 14-06-2008, 02:44 PM   #10 (permalink)
Self Confessed Geek
Yups, Dell has no reseller between the consumer and the company itself. You place the order directly on its Website
Old 15-06-2008, 09:39 AM   #11 (permalink)
Pro Geeks
Micheal's Avatar
THANKS TO ALL OF YOU who helped me decide. I am going for the Dell Inspiron 1525 with little customization. I had a go at other companies too, but no one is offering as much as Dell. Hope my trust on Dell doesn't get betrayed.
To vaibhav.Kanwal "Graphics card X300 will be sufficient enough for you needs and ocassional gaming too", yeah thanks a lot buddy. They r offering the X3100.
The website price is around 43K.
Thanks again all
Micheal
Micheal is offline
Old 15-06-2008, 05:01 PM   #12 (permalink)
gopz's Avatar
This doesnt hold good now, Dell has started reseller operations. There are so many dealers who stock Dell laptops. You might wanna do some research to find out who is the nearest Dell dealer in your city. Prices are the same but the advantage is that you get to see the laptop and purchase it immediately, instead of just looking online and waiting for a week for delivery of the product.
gopz is offline
laptop in range of 1200$ manishjha18 Hardware Q&A 8 04-11-2007 11:00 PM
Please suggest a laptop in 50 K range... ~Phenom~ Laptops and Netbooks 15 30-10-2007 03:44 PM
Suggest laptop in ~50k range koolbluez Laptops and Netbooks 2 25-08-2007 11:54 PM
sugest laptop in 45-55K range tgpraveen Laptops and Netbooks 3 02-08-2007 11:20 PM
