Old 13-06-2008, 11:56 AM   #1 (permalink)
Mobile Addict
Question External optical drive help
I know that portable hard disks can be made by inserting regular hard disks into hard disk casings. Can the same thing be done with optical drives.
I mean can i insert a regular DVD burner into a casing and access it using a USB port or Firewire port and carry it around.
I want to know if this is possible or not as external DVD burners are still very costly.
Please visit my site: hotshot05.page.tl or my blog: mobimad.co.cc for anything related to mobile reviews, games , applications and news. Please review my site.
aritrap is offline
Old 13-06-2008, 12:24 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: External optical drive help
I dont know, but if you want to carry data around, get 16GB USB drives, they are available, and are very light, lighter than carrying a DVD writer around.
dheeraj_kumar is offline
Old 13-06-2008, 02:01 PM   #3 (permalink)
ArZuNeOs's Avatar
yeah cases [IDE to USB] from tech.com & Zippys are available @~1000INRs ...u can get them to convert the internal DVDRW devices to external DVDRW devices...but on the precaution try to burn @ low speeds
else teh best way is to get Pen drives like dheeraj said the 4/8/16 gb ones....these are cheaper & viable in today's scenario
Back to the world of realms
ArZuNeOs is offline
optical drive direfulsky QnA (read only) 2 06-11-2007 06:22 PM
optical drive bhaudateju Hardware Q&A 2 02-10-2007 02:50 AM
how many cables for a optical drive ? 56561 Hardware Q&A 1 12-04-2007 03:18 PM
having problem in Optical drive . Please help . reddragon Hardware Q&A 15 14-07-2006 01:46 PM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
