Old 12-06-2008, 07:48 PM   #1 (permalink)
ComputerUser's Avatar
Exclamation Combo drive not shown
My CD/DVD combo drive is not being shown under Explorer and Device manager. The power cables are ok and there are reading sounds on inserting a disc. I tried the registry method to delete the upper and lower filters. What's the problem?
ComputerUser is offline
Old 13-06-2008, 05:11 PM   #2 (permalink)
Default Re: Combo drive not shown
This problem occurs because some registry keys are modified in the registry when you remove Digital Image.
more info....http://support.microsoft.com/kb/894730
good luck friend...however i am new here..and i dnt know much...
well i need ur response and support and plz do give me feedback if it did solve ur problem!!
chandal
chandal_keta is offline
Old 13-06-2008, 06:20 PM   #3 (permalink)
johnjjx's Avatar
try dis....remove the cables n reinsert them......check in bios..
e8400 / abit ip35-E / gskill 4gb / mx5021 + audigy 2zs / Visiontek 4870 / corsair vx450 / Dell E198wfp
johnjjx is offline
DVD Writer shown as CD drive... amitskale Hardware Q&A 4 22-04-2008 04:51 PM
Drive Not Shown neyo Hardware Q&A 4 22-07-2006 04:46 PM
Drive Not Shown neyo Software Q&A 3 22-07-2006 12:54 PM
pen drive not shown in my computer! tamilvendan QnA (read only) 5 15-04-2006 07:10 PM
Combo drive or dvd-rom cd-rw adhavan QnA (read only) 12 10-09-2004 06:23 PM
