Old 11-06-2008, 12:14 AM   #1 (permalink)
mortal kombat
quan chi's Avatar
Default urgent help required.pc behaving strangely.
hi friends.
from few days my pc often when turned on shows the message your windows could not start up properly due to a software or hardware change.
then there are options
start in safe mode
start windows normally
start in last known good configuration.
even when it was shut down properly.the last time and there was no power fault.
but today after selecting the last option also made the pc hang after showing the windows xp booting screen.
but it was opening properly in safe mode.
then i also started to system restore it.but in the middle of the system restore it would get hanged so i had to restart it again in safe mode.
later i was able to open it again in normal mode by selecting the last option.
please help.
quan chi is offline
Old 11-06-2008, 11:03 AM   #2 (permalink)
dhanusaud's Avatar
Default Re: urgent help required.pc behaving strangely.
Some OS's system file have been damaged.
Insert XPCDSP2 & repair ur system's OS. Defrag HDD as well.
dhanusaud is offline
Urgent help required Hari_04415 Software Q&A 4 16-08-2007 11:29 AM
urgent help required abt N95 GPS mohitgiri Mobiles and Tablets 4 16-06-2007 05:34 PM
SOS, Urgent help Required! Gigacore Chit-Chat 17 13-06-2007 12:39 AM
urgent help required.......... kuldeep bhardwaj QnA (read only) 1 10-11-2006 03:25 PM
urgent help required harshagarwal QnA (read only) 2 17-09-2004 01:25 AM
