hey by mistake removed the thermal paste between the processor and the fan is it necessary for it to be there if yes whats the approx. cost of it............
plzz suggest
thermal paste does help reduce procy temps by a fair margin.the cheapest thermal paste that u sud buy is CoolerMaster for bout 150-200 bucks.
Yes..thermal paste is important..even i removed it once...while cleaning out the heat sink unit. (Infact I cursed..the assembler at that time...saying..what the heck is this glue)...then I realized...my CPU was over heating..so I pasted CoolerMaster paste back on...!
If you have some high-end processor and you plan to do some OCing then go for a good Thermal paste. Otherwise buy some cheap thermal paste as suggested by pathik..
^^^ yup u can get thermal paste for 10 bucks.it comes in a small can and is white in color.
I Use As5 .....
U Can Also Get Cgeat Thermal Paste For 5-10 Rs
Dealers in EVGA,MSI,Corsair,Paliet Products,OCZ Memory ,Tagan SMPS & Many More
We are Authorized partner for ESET Products
Call me @ 9870803001
Have any of you guys tried that el-cheapo thermal paste with success ?
I think that cheap thing will work as a barrier between cpu heat sink heat dissipation. Also reduce the life span of th processor.
