Old 10-06-2008, 05:22 PM   #1 (permalink)
¦Rage--oצ's Avatar
Exclamation RAM prob!!
well a RAM chip has got golden coverings at the bottom my RAM is DDR2 but one the covering got removed as i put it upside down so the covering got scratched!! can that covering be replaced??? plzzz advice
¦Rage--oצ is offline
Old 10-06-2008, 08:25 PM   #2 (permalink)
dhanusaud's Avatar
Default Re: RAM prob!!
U sud mention brand of ur system's RAM.
AFAIK, there is noway to reassemble, if it works use it as it is
dhanusaud is offline
Old 10-06-2008, 08:31 PM   #3 (permalink)
Google Bot
Pathik's Avatar
ROFL! Insert it and see. If it doesnt work, there isnt much you can do about it.
Pathik is offline
Old 10-06-2008, 10:26 PM   #4 (permalink)
paranj
Posts: n/a
Buy a new one !
Ram Prob... BLAKX Hardware Q&A 3 11-09-2007 06:52 PM
IE Prob spynic Software Q&A 1 11-02-2007 10:21 PM
Prob... Prob... Prob.... kool QnA (read only) 2 18-07-2006 08:57 PM
Pc Fan prob.(Pls help this interesting prob.) Ishan Hardware Q&A 4 24-01-2006 09:38 AM
New prob with IE 6 Charley QnA (read only) 14 25-08-2005 03:36 PM
