Old 10-06-2008, 01:39 PM   #1 (permalink)
mortal kombat
quan chi's Avatar
Default now what is this problem.please help
hello friends.
i am having a problem.well this problem started two to three days ago.
and i have got this problem two times.
as i switched on my pc it opens the black option screen.it says we are sorry your windows didnot start up normally due to software or something problem ...etc etc..
then the options.
start windows in safemode
start windows normally
start from the last best configuration known.
but according to me i did not made any changes in the software drivers or any other things when i last time switched the pc off.then why does this message comes.
as i have mentioned i dont get this problem everytime.but sometimes it appears.
please help.
quan chi is offline
Old 10-06-2008, 01:42 PM   #2 (permalink)
Default Re: now what is this problem.please help
Windows might not have shut correctly the last time(Due to pressing the power button for 3-4 seconds or power cut)
ThinkFree is offline
Old 10-06-2008, 01:45 PM   #3 (permalink)
mortal kombat
quan chi's Avatar
^^well there was no powercut.and it shut down normally as i switch it off from the start menu.
quan chi is offline
Old 10-06-2008, 01:47 PM   #4 (permalink)
^^I got such problems only when Windows doesn't shut down properly
Old 10-06-2008, 02:24 PM   #5 (permalink)
At Hell's Disq
hellgate's Avatar
check hdd for errors.cud happen to corrupt system files.
may also happen due o power jitters.
hellgate is offline
Old 10-06-2008, 03:10 PM   #6 (permalink)
Super Moderator
asingh's Avatar
This happened to me once also. Try to log into safe mode..once. Then restart the system after the desktop appears. If the error still persists..then scan your disk for errors (let me know if you dont know how to do this). Best to do it from command prompt...!
asingh is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
