Old 10-06-2008, 01:37 PM   #1 (permalink)
channabasanna's Avatar
Default CPU Cooler.
Hi All,
Can anyone suggest a good CPU Cooler within Rs 2k, i would prefer a push pin type of cooler, because i dont want to risk by removing the motherboard, else i would need to take it to my dealer again to get a cooler fixed.
One i found was Hyper TX2, but found in reviews of newegg that fixing it is a problem. Few say because of that Cooler the board has changed its shape a little.
Also does it cause any damage to the motherboard because of its size and weight, as it will be hanging from the motherboard...
The Reviews link : http://www.newegg.com/Product/Produc...82E16835103031
Is there any other cooler, which is good to fit to my PC Configuration which is in my signature.
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
channabasanna is offline
Old 10-06-2008, 02:50 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: CPU Cooler.
hmm..it doesnt have any problems in installation afaik.i've used it on P5NE SLi.u can take Arctic Freezer 7.both AF7 and hyper TX perform the same.
if removing mobo isnt a problem go with a 90i + panaflo 90mm or scythe 120mm fan.its better
Apple Macbook Pro 17 :cool:
nish_higher is offline
hdd cooler ayushsobti Hardware Q&A 10 12-03-2007 04:21 PM
Which Cabinet and CPU Cooler to go for..... hotdogXP Hardware Q&A 13 02-01-2006 12:32 PM
