Old 09-06-2008, 10:43 PM   #1 (permalink)
Default Cheap and Reliable build
Hi
I just built a E4600 with Intel DG33FB config a month back.
I have to build a cheap and no-frills but reliable build to someone. Money is a key constraint...Lookign for cheaper than my previous build with E4600 and DG33
This time around I am not particular on Intel. AMD would also do. I am looking for on board graphics. No Gaming...No OCing
Can you pls offer a suggestion?
Thanks in advance...
tmbsundar is offline
Old 09-06-2008, 10:54 PM   #2 (permalink)
johnjjx's Avatar
Default Re: Cheap and Reliable build
Mention budget.also mention cmpnts needd.
Amd x2 4200+ 2.6k
Gigabyte nv7050 2.4k
1gb ram .8k
johnjjx is offline
Old 09-06-2008, 11:57 PM   #3 (permalink)
paranj
Posts: n/a
Intel E2140 + Intel D945G - 4.8k
1GB DDR2 667MHz Transcend RAM - 750Rs.
80GB Seagate SATA HDD - 1.2k
Zebronics Krissh Cabinet - 800Rs
Antec 450W - 900Rs.
LG E500 15" CRT - 4.2k
Lite-On LH20A1H - 1k
Odeyssey kbd+mouse opti-wired combo - 550Rs.
Creative SBS 245 - Rs. 700
Hope this helps.
Old 10-06-2008, 08:30 PM   #4 (permalink)
Thanks..
@John
I am looking at @15K. This is a basic build with on board video...
@paranj
Thx..Is it necessary to go for a separate PSU or go with one which comes with a cabinet as default (like Zebby Lava etc.,)
Old 11-06-2008, 07:14 PM   #5 (permalink)
Ranjya's Avatar
[QUOTE=paranj;
Antec 450W - 900Rs.
Hope this helps. [/QUOTE]
I did not know Antec was that cheap!
I would not have spent 2700 on CM500.
Ranjya is offline
Old 11-06-2008, 07:23 PM   #6 (permalink)
paranj
Posts: n/a
^^ya but its only for budget users, if u want to make a power PC than CM is the best. Real world output is less in Antec! @TC its not compulsory, u can get what u like. Both will perform the same nearly. I suggest u buy separate for warranty issues. So, when ur PSU goes kaput u have to only give ur PSU and not whole cabby. And Antec is a trusted company so i suggested it.
Cheerz!
Cheap & Reliable web hosting in India Sridhar_Rao Internet & WWW 22 29-06-2007 01:48 PM
Cheap and reliable dvd media jack// ani QnA (read only) 11 06-03-2006 09:30 PM
