Old 08-06-2008, 12:40 PM   #1 (permalink)
Ðèåd Måñ Wå£KîÑG
bad_till_bones's Avatar
Default Laptop - Display/Monitor - 13.3'' or 15.4''
Which one is better - 13.3'' or 15.4''?
Assuming the configuration same - Which one you will buy -
Dell Inspiron 1525
or
Dell XPS M1330
Once the game is over, the King and Pawn goes to the same box....
bad_till_bones is offline
Old 08-06-2008, 12:43 PM   #2 (permalink)
Default Re: Laptop - Display/Monitor - 13.3'' or 15.4''
Obviously one would like to buy the one with bigger screen if he is not required to carry it with himself always
ThinkFree is offline
Old 08-06-2008, 01:34 PM   #3 (permalink)
I M A *STAR*
saqib_khan's Avatar
The bigger 1, the better it is.
Blogging at:
Technostarry
saqib_khan is offline
Old 08-06-2008, 01:46 PM   #4 (permalink)
Ðèåd Måñ Wå£KîÑG
Yup, won't b carrying.
But, my colleagues told me tht 13.3'' is compact n good looking. Moreover, a 15.4'' becomes a big piece n not comes ideally in a lappy category.
But, my only worry is, will the 13.3'' look real small? Wud I b satisfied playing movies n games on it
Old 08-06-2008, 04:26 PM   #5 (permalink)
look most of the games will not support 15.4" I am playing 15.4" and only tomg raider supports the widescreen look.So, you might as well go for 13.3 if you are getting additional HDware with it.
atish is offline
Old 09-06-2008, 09:27 AM   #6 (permalink)
y2j826's Avatar
go for 13.3, it looks good
15.4 sometimes looks dumb
i had to choose between 15.4 and 14.1 when i was going to purchase laptop and i choosed 14.1 and now i feels i made a good deal that time . . .
http://worldofy2j.blogspot.com
y2j826 is offline
Old 09-06-2008, 09:38 AM   #7 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Re: Laptop - Display/Monitor - 13.3'' or 15.4''
13.3" is more portable over the performance factors. They are made for portability thus the screen is smaller. But the problem with these are most of the times they does not have a modestly powerful hardware to run the games in moderate settings. 15.4" is the standard size for the laptop which has the balance of both performance and portability.
debsuvra is offline
Old 10-06-2008, 03:28 PM   #8 (permalink)
Dell XPS M1330 if you have the money to pay extra...
realdan is offline
Old 10-06-2008, 03:43 PM   #9 (permalink)
Point Blanc
13.3 and 15.4 any you buy would have almost same weight, your carrying arround wont be affected by this. Take 15.4 screen size because 13.3 becomes too small and even 1280x800 resoultion would seem to be bad on it. only if you wanna strain your eyes alot.
15.4 comes in lappy category very well its not 17 inch that it will look very big.
Guys portabilty comes with weight of the lappy and not just size(not for 13.3 or 15.4),
infact 13.3 and 17 both costs more than 15.4
acewin is offline
Old 10-06-2008, 04:19 PM   #10 (permalink)
a_k_s_h_a_y's Avatar
15.4 is soo heavy that my father has dumped his laptop away in the office.
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 10-06-2008, 04:41 PM   #11 (permalink)
gopz's Avatar
If the resolution is any better than 1280 x 800, then you might wanna consider 15.4"
Otherwise, I think you will be fine with 13.3" at the same resolution.
gopz is offline
No Display in Monitor Soumyajit Hardware Q&A 4 08-10-2007 04:49 PM
Monitor display is all Pink. Neha.N Hardware Q&A 15 29-03-2006 06:03 PM
monitor display problem abhishek_sharma Hardware Q&A 2 19-02-2006 09:15 PM
Monitor can't display graphics! Satissh S Graphic cards 2 25-12-2005 10:10 PM
