Old 07-06-2008, 08:08 PM   #1 (permalink)
Ashok Verma's Avatar
Exclamation Sony DVD-RW tray not working properly..
hope you got the problem...! please help!!
i am facing this problem from a few days....! earlier it was working well!!!
and the problem priests only when the dvd drive is empty.. i.e., when we have a disk inside it, it opens effortlessly....?
now i have to use papercilp or pin in conjunction wen i press the eject button.
the problem is same even if i used to eject drive tray in windows by right clicking the context menus?
Dvd drive: SONY DVD RW DW-Q120A
Ashok Verma is offline
Old 07-06-2008, 10:02 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Sony DVD-RW tray not working properly..
Maybe a hardware problem... give it for service? They do it for free if under warranty (their warranty states that physical damage like tray is not covered under it, but still they do it for free)
dheeraj_kumar is offline
Old 08-06-2008, 10:53 AM   #3 (permalink)
hey buddy warranty is over....!!!!
still they do it for free....!!!
Old 08-06-2008, 11:10 AM   #4 (permalink)
Oh, I didnt know that... I think its just your vendor who helps you, hehe Mine wont, so hopefully I wont break my tray in the near future!
Old 08-06-2008, 11:14 AM   #5 (permalink)
channabasanna's Avatar
May be because of more usage of the Drive, the gears in the tray would have been broken, the same had happened for my SAMSUNG dvd writer, once i got it repaired under service, later again same issue. So i brought a SONY...
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
channabasanna is offline
Old 08-06-2008, 11:47 AM   #6 (permalink)
if the gears are broken then why tray opens smoothly (without any problem) with a disk in it....??? (mention earlier also)
please give suggestion:---
as now warranty is over. should i open it for some lubrication.....??
i think this could be the cause of problem...!!!
Old 08-06-2008, 12:06 PM   #7 (permalink)
-----ATi-----
nvidia's Avatar
I think its best if you pay and get it repaired. Lubricating it yourself is not recommended.
http://twitter.com/akshayms
nvidia is offline
Old 08-06-2008, 10:03 PM   #8 (permalink)
Same was the case with me, when the disc was in the tray it would open without any hassles, or any problems. Only problem i had was when there is no disc inside the tray, i had to push a pin into it to open.
I never did any lubrication.
I had opened the drive only after getting a new drive. So just try to know how much does it cost to repair it, if it goes above 200 - 300, i would say you better buy a new writer if possible..
Old 08-06-2008, 11:19 PM   #9 (permalink)
Thanks for the suggestion friend. lets see how much did it cost to me?
thank you very much again.....
Old 11-06-2008, 12:21 PM   #10 (permalink)
15.0 GHz
VarDOS's Avatar
The Gear Of The Drive Might Be Broken
VarDOS is offline
Old 02-12-2008, 01:18 AM   #11 (permalink)
I was having the same problem a few days back.
Now its getting worse
It does not open even when there is a disc inside
mandeep_m91 is offline
Samsung Cd Writer tray Not working properly saurabh kakkar Hardware Q&A 9 27-01-2008 12:16 AM
speakers are not working properly vicky_l7 Audio 3 30-09-2007 11:31 AM
Celeron D not working properly... hpotter606 Software Q&A 6 16-07-2007 05:01 PM
Help-Pendrive not working properly!! rajivrocks Software Q&A 11 16-03-2007 01:15 AM
DVD writer not working properly blacklisted Hardware Q&A 12 31-07-2006 10:40 AM
