Old 06-06-2008, 09:20 PM   #1 (permalink)
mortal kombat
quan chi's Avatar
Default i have one problem - CPU Fan buzzing sound
greetings friends
for the past 2-3 weeks my cpu fan is making a buzzing type of sound.after 10-15 minutes when ever i turn on the pc.
then i found out that when the fan's speed increases the plastic rib on which it is supported or fixed.vibrates and makes that buzzing sound.
when i press that rib the sound stops.but when again i free the rib it starts vibrating again.
if i hit the sides of the rib few times during the buzzing.then also it stops.but later again when i turn on the pc.it starts.
please help is there anyway i can stop it.
quan chi is offline
Old 06-06-2008, 09:24 PM   #2 (permalink)
Default Re: i have one problem - CPU Fan buzzing sound
You probably have a wire touching the side of the fan, or maybe its dirty, or maybe the screws are loose- solution open her up,clean everything,tighten whats loose.
Our deepest fear is not that we are inadequate Our deepest fear is that we are powerful beyond measure
karmanya is offline
Old 06-06-2008, 09:27 PM   #3 (permalink)
paranj
Posts: n/a
Its 90% wire touching prob. i had it once
Old 07-06-2008, 12:25 AM   #4 (permalink)
mortal kombat
quan chi's Avatar
well i did opened the cabinet.but didnt found any wire passing near it.btw how to tighten it?
quan chi is offline
Sound problem-Please help SunnyChahal Hardware Q&A 5 11-03-2008 11:07 PM
Sound Problem with Nvdia onboard Sound (hda-intel) Maverick340 Open Source 4 18-09-2007 11:12 PM
sound problem jmit QnA (read only) 3 07-05-2006 06:46 PM
Sound Problem zodiac_511 QnA (read only) 11 28-08-2005 10:05 PM
sound problem in xp krishi20s Software Q&A 1 03-03-2005 01:02 PM
