i wanted to buy a linksys wireless adsl router. now which1 to buy? there r two technologies 802.11n and 802.11g. can any1 explain whts the difference between them. which1 to buy and which1 wud be expensive?
if u can afford then get the 802.11n router.u'll get a higher rate of transfer and get bigger coverage area.
