Old 06-06-2008, 02:46 PM   #1 (permalink)
Question Which is faster - PCMCIA Data Card or USB Modem or Cellphone
Hi, if the choice of the internet connection has to be made between these 3 types of wireless connections, which is the faster connection, independent of the service provider
1. PCMCIA Data Card
2. USB Modem (as provided by Reliance/Tata)
3. Cellphone connected through a USB data cable with EDGE
Right now i dont find anything special to mention in my signature
zatang is offline
Old 06-06-2008, 03:23 PM   #2 (permalink)
kumarmohit's Avatar
Default Re: Which is faster - PCMCIA Data Card or USB Modem or Cellphone
EDGE Phone over USB, provided you get EDGE speeds!
PCMCIA EDGE data cards are also available AFAIK.
kumarmohit is offline
Old 06-06-2008, 05:08 PM   #3 (permalink)
USB modem and PCMCIA card must provide the same speed as they use the same network. As per my experience, you get better speed on CDMA network than that on EDGE
ThinkFree is offline
Old 06-06-2008, 10:58 PM   #4 (permalink)
Legendary Darknight
latino_ansari's Avatar
I have used both a USB modem(Reliance CDMA) as well as airtel gprs on ma cell phone.... As my experience goes the whole speed thing depends on the signal strength in ur area..... But CDMA usb modem will give u good speeds if signal strength is high....
latino_ansari is offline
Best internet data modem/card in NCR ? esumitkumar Mobiles and Tablets 11 18-02-2008 09:41 AM
PCMCIA card or USB Modem for Reliance Netconnect ? VexByte Mobiles and Tablets 8 19-08-2007 12:01 PM
Cheapest Cellphone,That i can use as modem! Orionz Mobiles and Tablets 2 03-11-2006 06:00 AM
PCMCIA Ethernet Card ? cyberia.in QnA (read only) 1 03-10-2005 08:31 PM
Airtel Data card is a PCMCIA & i want use it minniawochat Broadband and DTH 1 18-08-2005 12:23 AM
