Re: Core2Duo OR Core2Quad?????
for the mobo the best u can get in ur budget is abit IP35-E for 5.4k.it has everything u need except e-sata.
the choice of procy will depend a lot on wat u'll be using ur pc for.for most apps the E8400 will perform better than Q6600 due to its sheer processing speed (3GHz vs 2.4GHz).
when oc'd to 4GHz perf inc is gr8.
