Old 05-06-2008, 11:27 AM   #1 (permalink)
channabasanna's Avatar
Default RAM Upgrade of Laptop
Hi All,
I have HP dv2601tx laptop, right now it has 1GB DDR2 66MHz RAM, i want to upgrade to a 2GB RAM, later i would prefer buying one more 2GB RAM supports upto 4GB RAM, So can i know which brand to go for the RAM, or should i take it to my hp dealer where i can get the RAM.
What would be the cost of 2GB RAM.
Also can i install windows xp into that laptop, if so where can i get the drivers for XP, in hp site i could not all the drivers which were needed for the model.
HP dv 2601tx features:
  • Intel Core2Duo Processor 1.5 GHz
  • Intel 965GM Chipset
  • 1GB DDR2
  • 160 GB Serial ATA
  • 8X SuperMulti Double Layer (8.5 GB) DVD +RW/ +R Writer
  • NVidia GeForce 8400M 64Mb Dedicated
  • 14.1" WideScreen (WXGA) with BrightView Technology
  • Windows Vista Home Premium
  • Integrated Bluetooth
  • Integrated 802.11a/b/g
  • 5-In-1 Digital Media Reader
  • Integrated 56K Modem
  • Remote Control
  • Integrated 1.3 Megapixel Webcam
  • Finger Print Reader
  • Microphones
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
channabasanna is offline
Old 05-06-2008, 04:32 PM   #2 (permalink)
Default Re: RAM Upgrade of Laptop
If you plan to get the RAM yourself then opt for Transcend as these are OEM suppliers to nearly all the manufacturers.
AMD Phenom II X4 955 BE, Asus M4N98TD EVO, 2x2 GB G.Skill @ 1600MHz, MSI GTX 560Ti Hawk, 500GB Western Digital Black SATA-II, Dell Ultrasharp U2311H, CM 690, Corsair VX550
monkey is offline
Old 05-06-2008, 06:10 PM   #3 (permalink)
I s33 G33ky p30pl3
Here is your solution hope it helps,
Official HP drivers
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=354 5116〈=en
For Intel Chipset Drivers visit
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&ProductID=816&DwnldID=14528 &strOSs=44&OSFullName=Windows*%20XP%20Professional 〈=eng
and choose your chipset drivers
For nVidia Drivers
http://drivers.softpedia.com/get/GRA...Go-15655.shtml
For ALPs Touchpad:
http://h10025.www1.hp.com/ewfrf/wc/g...x?cc=us&dlc=en
Hope this helps, sometimes after installing the audio drivers for XP, XP sometimes doesn't recognise the sound card for that download the patch from microsoft website
http://support.microsoft.com/kb/835221
Cheers..
I'm not a G33K, i still use Windows!
I dream of a better tomorrow... where chickens can cross roads and not have their motives questioned.....
shivg33k is offline
Old 06-06-2008, 05:00 PM   #4 (permalink)
What will be the cost of the 2GB stick.
Locate Laptop - locates your stolen laptop! parthbarot Technology News 11 16-03-2008 11:29 AM
MOST EXPENSIVE LAPTOP - Luvaglio announces world’s most expensive laptop techtronic Technology News 1 27-03-2007 02:19 PM
Laptop Lan Config error work only with laptop not with pc minniawochat PC Components / Configurations 4 19-09-2006 03:21 PM
