Old 05-06-2008, 09:38 AM   #1 (permalink)
Question SMPS for this spec..PLZ...!
Hi all,3 smps changed in 5 months..suggest me a better smps plz
P4 3.0GHz HT
2GB RAM
80GB+320GB hdd
ATi Radeon X600/X500 series
Sony DVD writer
17" AOC LCD monitor
Pinnacle TV/FM tuner(not connected due to Vista incompatibility)
Vista Ultimate SP1
eMerge 500KVA ups
Zebronics 400W smps (previously Intex 450W & some brand 400W)
Similar questions may be asked many times.
But,kindly help me for the above configuration...plz.!
ksundar is offline
Old 05-06-2008, 10:44 AM   #2 (permalink)
I s33 G33ky p30pl3
Default Re: SMPS for this spec..PLZ...!
Go for Cooler Master Extreme Power 600W for Rs 3,200/- good and stable for your config.
I'm not a G33K, i still use Windows!
I dream of a better tomorrow... where chickens can cross roads and not have their motives questioned.....
shivg33k is offline
Old 05-06-2008, 11:36 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ Isn't Cooler master RS-380-PMSR 460W SMPS enough for that config and is available for some 1700 bucks. Isn't a 600W too much for that config and also results in heavy power bills.
desiibond is offline
Old 05-06-2008, 12:32 PM   #4 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
exactly
+ go check the specs of that 600W PSU.it does not have an 8-pin CPU connector..so a total waste of money in every way.
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 05-06-2008, 02:31 PM   #5 (permalink)
At Hell's Disq
hellgate's Avatar
getting a higher wattage psu than wats reqd by the system doesnt mean that u'll hafta foot heavy pwr bills.
if a system draws 230w of pwr at full load and ur using a 650w psu,the psu u'll supply only 230w or pwr as is reqd by the system.it wont draw 650W.so it wont inc pwr bills.wat it'll do is it'll give u more headroom for future upgrades.
hellgate is offline
Old 05-06-2008, 02:41 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ what kind of setup would you need that will kill a 630W SMPS???
Look at that config. buying a 600W SMPS for that tiny config is just waste of money. For the extra 2k that is saved, you can get 160gig HDD or 2gig ram etc.
Getting a 600W PSU only because somewhere in future you may/may not upgrade your system to a monster that only 600W can handle, doesn't make any sense.
Old 05-06-2008, 02:48 PM   #7 (permalink)
At Hell's Disq
hellgate's Avatar
i aint suggesting him to get a 600w psu or above.wat i wanted to say was that getting a higher wattage psu doesnt mean that u'll hafta foot heavier pwr bill as u said.
hellgate is offline
Old 05-06-2008, 03:31 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
ah. okay. Now, I got it. thanks for the heads up.
Old 05-06-2008, 08:28 PM   #9 (permalink)
frankly i would get the higher capacity one i.e the 600W one
i dont see it as a waste of money to go for a higher capacity than you need, the guy would sooner or later have to upgrade most probably in the event of failure of processor or motherboard.
I used to buy according to power requirement but now if i can afford i buy not only a higher wattage one but also a higher quality one from the same manufacturer
frankly adding further ram is of no use to his config
fortunately for him it is his power supply that failed first and not his other components..so if you have the money, you can invest in a higher capacity one of at least 600W which people around here can suggest which one is more better for the future
realdan is offline
Old 05-06-2008, 11:25 PM   #10 (permalink)
At Hell's Disq
hellgate's Avatar
its always better to go in for a good psu with a higher rated wattage than wats reqd by the system at max load.getting a good psu gives u the peace of mind that u wont be having any pwr related probs in ur pc.
hellgate is offline
Old 06-06-2008, 08:45 AM   #11 (permalink)
This is a Gr8 Forum!
Thanks to all for nice suggestion!
If I want to buy 600W smps in Chennai? Is there any specific shop in Ritche Street?
Is there any price catalogue for smps? Plz suggest me..!
ksundar is offline
Old 06-06-2008, 09:07 AM   #12 (permalink)
Alter Bridge=GOD
why dont u go for CM Real Power 550W instead of this 600W PSU..u r gonna have problems with this PSU when u upgrade-it doesnt have an 8pin power connector.
read any mobo manual..it matters.rest upto u
Old 06-06-2008, 12:10 PM   #13 (permalink)
mortal kombat
quan chi's Avatar
how much will be an vip400watt smps.and how much amp does it have on 12volt rail.
quan chi is offline
Rate this spec out of 100 karina_got_it Hardware Q&A 3 16-01-2008 05:48 PM
Mother board spec sivarap QnA (read only) 4 12-04-2007 07:32 PM
Is this sys spec enough to run Unreal 2004 dspmunna Gamerz 3 05-02-2006 12:48 PM
SMPS spec. medigit QnA (read only) 4 27-07-2005 10:04 PM
