......And my bad luck continues.
Yesterday night, my machine turned off suddenly. Motherboard got power as I can see my soundcard Supreme Audio FX II glowing blue. But as I press power button on my cabby, the psu (Tagan BZ 800 watt) and one of my cabby led fans (Antec 900) blinks and then turns off. From the second time onwards, as I press power button, nothing happens.
I thought for a time that the power button has gone wrong. My motherboard (Asus Maximus Formula) has got onboard power switch. I tried using that button too but the result was same.
The weired thing is that when I turn off the main switch on the switch board and turn it on again, for the 1st time, when I press power button on my cabby, the psu and cabby fan blinks for once as if its going to turn on and then the system turns off.
I also checked with the power cord of the psu and used a different power cord. The result was the same.
Sometimes, even my motherboard is not getting power as the Audio Card led doesnt glow when I turn on the psu.
I was using my Corsair HX 620 watt power cord with the Tagan psu as the TAGAN power cord has no ground pin.
Now I cant detect where the fault is. Please suggest me how I can detect where the fault has occured. I am rite now quite confused.
Thanks.
