Old 04-06-2008, 08:04 AM   #1 (permalink)
Most wanted
rohan_mhtr's Avatar
Default Unable to use usb joystick
I recently got myself a cheap usb gamepad which looks same like a ps2 joystick and has all the buttons . Its manual say that it is a usb dual vibration joystick with macro .I am not able to use this joystick . When i check in device manager , there it shows that drivers of this hardware is not installed and when i click update driver then after the setup an error occurs which says :
There was a problem installing the hardware usb joystick
An error occurred during installing this device
A service installation section in this INF is invalid .
I am using xp sp2 . the driver cd that came along with it has a corrupted setup file .I think that this is a driver issue and not a hardware issue since light glows on the joystick when i connect it to usb port . Is there any way that i can get this thing running by using drivers of some other joystick .
rohan_mhtr is offline
Old 04-06-2008, 10:07 AM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Unable to use usb joystick
Post a picture of your joystick... we may have drivers for that...
dheeraj_kumar is offline
PS 1 Joystick In PC ashiksn1 Software Q&A 2 22-10-2007 11:52 AM
JoyStick? LEARNER_LEARNER Hardware Q&A 1 29-03-2007 08:55 PM
Gamepad or Joystick? Knight Gamerz 1 26-11-2004 02:12 AM
