hey hellgate have you check the review on techtree for G1S and G2K, they are good.
the specs of the HP lappy is also decent, it has 256 MB 8400GS GPU
another model 1K costlier than the dv3005tx is
HP Pavilion dv6767TX Thrive Special Edition Entertainment Notebook PC (KP162PA)
it has +1 GB RAM and 15.4 against 13.3 of dv3005tx and the weight comparision of the two is dv3005tx is 2Kg whereas dv6767TX is 2.78 Kg
if you are in Bangalore then you can check both models in the malls easily to get a lookup of them.
Now, I started to check my favs, seems people wanna show some real competition to Dell, alot more Sony vaio models as compared to my last visit, you have whole price range to look into them.
Complete Range of Sony Vaio Laptops - Check the Vaio CR range, they are all 14.1 WS
according to me vaio would be better than HP because they look better in all sense than HP lappies.
