Old 03-06-2008, 05:21 PM   #1 (permalink)
Default computer freezes after connecting to net?
hi
this is my third post in the last 15 days regarding my problem. dont know y no1 is interested in trying to help me? i am having this problem for the last 15 days. whenever i connect to the net within 5-10 mintues my pc freezes. i scanned using mcafee but no virus found. wht cud be wrong? any other virus scanner to check? plz reply.
raja2281 is offline
Old 04-06-2008, 04:52 AM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Default Re: computer freezes after connecting to net?
What broadband connection are you using ?
Dataone or Airtel
techtronic is offline
Old 04-06-2008, 04:07 PM   #3 (permalink)
i use local cable internet. but why r u asking this?
raja2281 is offline
Old 04-06-2008, 06:24 PM   #4 (permalink)
k_blues24's Avatar
If u hv mobo cd, install drivers of ethernet or consult with isp
Reinstall ur browser
k_blues24 is offline
Old 04-06-2008, 06:41 PM   #5 (permalink)
In general, AFAIK, McAfee AV is not that great these days... Plus, you also need to protect against spywares, malwares, etc, for which I dont think McAfee will do well... First, install antispyware scanners such as Adaware, Spyware Doctor and Spybot SnD and update their definitions to the latest... Then, run a scan with these tools and with McAfee in Safe Mode... Then, if problem persists, get HijackThis and post its log here... We can check what malware are there...
EDIT: I hope you have a decent firewall in place...
Arun
sakumar79 is offline
Old 04-06-2008, 08:52 PM   #6 (permalink)
ok from hijack this we can make out if we have malware ?
raja2281 is offline
Old 05-06-2008, 12:25 AM   #7 (permalink)
techtronic's Avatar
IMHO, Kaspersky Internet Security is a very good piece of Software especially designed for both Internet as well as Home Security.
Well I had this freezing issue on my Gigabyte GA-P35C-DS3R Motherboard initially.
The problem was the Duplex in the Onboard NIC.
My ADSL BSNL Modem (SmartAX MT 880) only supported 100 Mbps while the onboard NIC was supporting 1 Gbps.
Changing the duplex to 100 Mbps on both sides fixed the issue.
Old 05-06-2008, 12:30 AM   #8 (permalink)
macaddict
gauravsuneja's Avatar
format kar le yaar agar isse bhi nahin thik hoat toh hardware ka funda hai cpu garam ho rahahoga.chek ur smps
gauravsuneja is offline
Old 05-06-2008, 07:04 PM   #9 (permalink)
have already formatted twice. but no use. also hardware main ram, hdd , modem etc already checked. did some scan and found some spyware. lets c if that helps
also that 1gbps connection thing i will change it to 100 mbps and then check
raja2281 is offline
Old 05-06-2008, 07:37 PM   #10 (permalink)
Debian Gnu/Linux User
Sathish's Avatar
Thumbs up Re: computer freezes after connecting to net?
1 Uninstall your Network CARD from add remove hardware...
2. Restart ...
3. Install necessary Network driver...
4. Set necessary IP addresses..
Sathish is offline
Old 05-06-2008, 07:37 PM   #11 (permalink)
i have checked for spywares. found some removed them. but still the computer freezes.
also changed the duplex mode to 100 mbps of the onboard nic still the computer freezes.
how do i check heating of cpu or smps? question is they cannot get overheated in just 5 min of starting the pc.
what r the options left? or else will have to call the assembler to get it working.
raja2281 is offline
Old 05-06-2008, 08:18 PM   #12 (permalink)
Intel OCer
amitash's Avatar
U can check ur cpu temperature using an app called coretemp google and dload it to monitor processor temps....i would suggest a software called EVERESt it can monitor all the temps in ur config...also post ur config here.If its not a temp or software problem then u had better contact ur dealer asap
My site: collegeclassroom.org
amitash is offline
Old 05-06-2008, 08:20 PM   #13 (permalink)
what procedure do you use to connect to the net...?
realdan is offline
Old 05-06-2008, 09:17 PM   #14 (permalink)
to connect the net isp has provided a client software wherein we type the login info and connect it.
raja2281 is offline
Old 08-06-2008, 07:53 PM   #15 (permalink)
hi thx to all of u for replying.
now i have got the issue resolved.
i installed norton internet security and it detected some 37 infected files with w32.almanahe.b virus that makes the connection to internet and kills processes. thats y system used to freeze when connected to net.
raja2281 is offline
Old 09-06-2008, 07:54 AM   #16 (permalink)
techtronic's Avatar
Nice to hear that finally.
COMPUTER FREEZES after booting ? raja2281 Hardware Q&A 7 23-05-2008 04:30 PM
help my computer freezes gauravsuneja Hardware Q&A 21 31-12-2007 07:48 AM
Computer freezes!!! sudhix Software Q&A 2 04-01-2007 11:22 PM
do we need hub when connecting 2 computer by lan digiFriend Software Q&A 5 31-03-2006 12:59 AM
computer freezes when I start surfing Gaurav Software Q&A 12 06-01-2006 10:14 PM
