Old 03-06-2008, 04:35 PM   #1 (permalink)
Default Cheap internal Tv tuner card
please help me choose a good internal card ( cheaper ones ) . Mainly used ofr capturing and watching tv
And mainly compatible with vista . i have seen vista Switch to basic theme when using a Tv tuner card bundled software . why is that happening ?
thanks
eureca_eureca is offline
Old 03-06-2008, 07:07 PM   #2 (permalink)
99.9% Idle
axxo's Avatar
Default Re: Cheap internal Tv tuner card
you can get a pixelview playtv pro 3, a vista compatible(not mediacenter ready) for 1k exactly. The switching occurs only if overlay mode is enabled in the software.
axxo is offline
Old 03-06-2008, 07:37 PM   #3 (permalink)
Problem exists without over lay enabled . right now i have a zebronics tv box TV2007 , its working fine on vista , i need an internal card
Internal or external TV Tuner Card? Yogesh Sarkar Hardware Q&A 12 05-10-2008 03:20 PM
internal tv tuner card reddevil2 Hardware Q&A 1 13-12-2005 10:40 PM
