Old 03-06-2008, 02:49 PM   #1 (permalink)
channabasanna's Avatar
Default Maximum Hard Disk capacity detected
Hi All,
Can i know what is the maximum Hard disk capacity that a windows xp disk can detect, not the sp2 disk. When i used that normal xp disk for my 320GB Sata HDD it just showed 120GB and did not detect the other 80GB IDE HDD, but when i used my XP with SP2 disk i could see all the hard disks.
So is there any limit like that.
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
channabasanna is offline
Old 03-06-2008, 03:26 PM   #2 (permalink)
Default Re: Maximum Hard Disk capacity detected
yes there is limit to hdd you can use with your mobo.depends on mobo(correct me if i am wrong)
techtricks.co.in
portforwarding
xp-vista crossover connection
installing xp on vista notebooks
sreenidhi88 is offline
Old 03-06-2008, 03:58 PM   #3 (permalink)
If that is the case then why did the disk with SP2 show the complete Hard Disk.
Also in BIOS all hard disk with its full capacity were displayed.
My older rig was P4 2.66GHz, Intel D101GGC motherboard, 1GB and 512MB DDR400Mhz RAM.
I have not tried in my new rig. But just installed windows from my sp2 disc on it, which showed all HDD.
Old 03-06-2008, 05:23 PM   #4 (permalink)
oh sorry man i misunderstood the question in first place.i ws thinking about hardware limitation.
techtricks.co.in
portforwarding
Old 04-06-2008, 12:31 AM   #5 (permalink)
Point Blanc
xp without any service pack, the original release identified less than 160 GB HDD, this is not a mobo issue but OS issue
acewin is offline
Old 04-06-2008, 01:24 AM   #6 (permalink)
crazydevil's Avatar
one of my friend is using 250GB SATA and 89GB IDE hard disks with out any type of probs
crazydevil is offline
Old 04-06-2008, 07:08 AM   #7 (permalink)
Point Blanc
then get it cleared is he using XP with Service Pack 2 or without any Service Pack no even SP1.
acewin is offline
Old 04-06-2008, 11:22 AM   #8 (permalink)
I agree with you acewin, i just wanted to confirm this. Thank you...
Old 04-06-2008, 07:31 PM   #9 (permalink)
yes THIS is not mobo issue.what i meant was there is a limitation (hardware) for max hdd size.like my motherboard can't support greater than 2tb as told by paranj.
(whose gonna buy a 2tb hdd anyways)
techtricks.co.in
portforwarding
Old 04-06-2008, 11:17 PM   #10 (permalink)
one day people will buy in TB...it is coming closer and closer
realdan is offline
Old 06-06-2008, 03:50 AM   #11 (permalink)
Point Blanc
well its already true, there are people who would have got 1 TB of HDD
acewin is offline
Brand new hard disk not being detected. jawash QnA (read only) 2 04-06-2008 04:53 AM
Laptop Hard Disk - Maximum size in INDIA...!!! sunandoghosh Hardware Q&A 3 01-08-2006 09:23 PM
Hard Disk Capacity divyadbzgt1 QnA (read only) 11 02-09-2005 10:28 PM
Is hard disk eating the capacity or the operating system? Santosh Halemani Software Q&A 5 13-12-2004 11:13 AM
