Old 03-06-2008, 11:01 AM   #1 (permalink)
Exclamation usb not recognised
hi all,
i recently bought PRONET usb wireless adapter.got usb extension cable with that with which it works fine .but thats v. short.when i tried to connect another usb extension cable the balloon message appears as "not recognised".my motherboard has 6 rear usb ports out of which 2 are busy with another devices.tried 2-3 cables,removed other usb devices ,also ps2 to usb converter but none worked.is that a power issue of usb ?please help me getting good wireless signal strength by getting that cable recognised. my details as follows:
OS:win Vista 32
MB: DG33FB
PR:E4500 C2D @2.2 GHz
no FP usb,6 rear usb ports
chetan55 is offline
Old 03-06-2008, 12:58 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: usb not recognised
Unrecognized USB Device Problem
ravi_9793 is offline
Old 05-06-2008, 10:25 PM   #3 (permalink)
Exclamation Re: usb not recognised
i tried everything, not working
its important please help,
i am getting signals from far away are v. weak
plz help...
chetan55 is offline
DVD RW Not recognised in explorer rajat22 Hardware Q&A 3 01-10-2007 01:47 PM
DVD doesn't get recognised..!!! rakesh-the gilli QnA (read only) 6 22-06-2007 05:40 PM
USB drive not recognised in Windows XP sanjiban_ghosh Hardware Q&A 1 27-12-2006 07:05 PM
Some discs noty recognised... mario_pant Hardware Q&A 7 01-07-2006 09:19 PM
Floppy Media not recognised Plz help angel_dinesh QnA (read only) 11 07-07-2005 05:10 AM
