Old 03-06-2008, 10:46 AM   #1 (permalink)
Default the best ethernet card for desktop??
guys i am buying a new ethernet card for my desktop?anyone got any suggestions?
pls reply
techtricks.co.in
portforwarding
xp-vista crossover connection
installing xp on vista notebooks
sreenidhi88 is offline
Old 03-06-2008, 10:58 PM   #2 (permalink)
Point Blanc
Default Re: the best ethernet card for desktop??
buy any of the ethernet card like D-Link or intex or netgear coming in Rs 300, will actually seem to give you similar performance, but if you are buying wireless card then it can be different.
acewin is offline
Old 03-06-2008, 11:03 PM   #3 (permalink)
TheSaint
NucleusKore's Avatar
Also your primary use. If it's just for broadband then regular card as suggested above. If it is for specialised applications like high speed networks or cluster computing then a gigabit ethernet card and a gigabit switch
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 03-06-2008, 11:08 PM   #4 (permalink)
dOm1naTOr's Avatar
Intex one fails frequently. Ive replaced mine almost 5 times in one year. Im goin for a better one like D-Link.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 04-06-2008, 12:41 AM   #5 (permalink)
Point Blanc
yup intex of lower quality than D-Link, but your reporting of the issue is too much, 5 times in a year man, really serious heehe, my firends used it for so long when I was studying, and in high use LAN but no issues.
But yes D-Link is a little better and a little costlier(better because its D-Link product) than intex
acewin is offline
Old 04-06-2008, 01:31 AM   #6 (permalink)
dOm1naTOr's Avatar
each time it was replaced with a new one. My first, nd thrrd was dead. All others had BSOD problem, when lan activity was above a certain level. If normal browsing, then no probs. If i dl somethin or transfer file/MP game, then BSOD appers on ny of the system saying 'NDIS.sys" acting illegally. Its the net send error detecting file. No probs if i use onboard lan. But i need to use lan nd net simultaneously[on my 3 systems].
G3: XPS M1530 |
FZ 16.
Old 04-06-2008, 03:40 PM   #7 (permalink)
you are just late guys.i just brought intex one(something named computex)cost me 295.illl mbe uploading pics later.along with that bought 80 conductor ata cable 25 rs each.
this card is working fine..i bought it for downloading purposes,earlier i used to have usb connection.last night i downloaded over 2gb content.
techtricks.co.in
portforwarding
Ethernet card problem yash.yash Hardware Q&A 1 07-04-2008 09:12 AM
Lan card or Gigabit ethernet bbalegere Hardware Q&A 2 28-03-2006 11:37 PM
ISA ethernet card jack// ani QnA (read only) 6 08-11-2005 03:28 PM
Ethernet card godsownman QnA (read only) 15 25-08-2005 11:56 PM
connect laptop and desktop using ethernet setharsh Laptops and Netbooks 2 09-07-2005 06:10 PM
