you need to reset your DMA mode setting, I had actually tried this, as someone had made post of this giving link
Click on Download in the link
it will give a vbs run this and you will find your issue resolved.
Besides this
Nero 8 CleanTool, this is another of good util I fond from thinkdigit.
Follow this step and then rest DMA script, if just resetting DMA doen not helps.
Besides long time you may also need to folllow this step if it gives "No Seek" Error or "Disc at once" while working with Nero, while burning I see the system res utilization goes high so, let only burning go(I am also amazed of this because earlier I used to burn using nero and play side by side, except my burner is different than yours.
