Old 02-06-2008, 05:41 PM   #1 (permalink)
Simpsons rox
Default TV tuner queries
i want to buy a good tv tuner card internal one.
also give mumbai price
possible. pls suggest one with wide screen support andf tata sky,etc works then preferable.
recordin quality should be good. looking for VFM.
apart from this i have certqueries of how TV tuner works like
do tuner cards work well with widescreen LCD monitors.
if i am wa one channel can i record another channel
can i record more than one channle at the same time
can i watch more than one channel at same time PiP it's called i think if so can i route the audio thru the two audio outs that i have.
thx in advacne.
T.G. Praveen
A computer program does what you tell it to do, not what you want it to do.
Visit my site at www.praveen.co.nr
tgpraveen is offline
Old 04-06-2008, 04:17 PM   #2 (permalink)
Simpsons rox
Default Re: TV tuner queries
bump pls reply someone
T.G. Praveen
Queries:TV Tuner,Ram,DVD-RW bajaj151 Hardware Q&A 1 04-05-2008 04:21 PM
Two queries about XP... aryayush Software Q&A 31 12-09-2007 10:51 AM
n73 queries.. tgpraveen Mobiles and Tablets 1 11-05-2007 11:02 AM
Several Queries Aijaz Akhtar QnA (read only) 1 27-02-2005 07:43 AM
My Queries regarding Tv-Tuner Card. Needs Advice from you. Yoda QnA (read only) 12 26-01-2005 12:06 AM
