Old 02-06-2008, 05:18 PM   #1 (permalink)
Alpha Geek Banned
bikdel's Avatar
Question WIFI Router with ADSL 2+
Guys, Im looking for a Wifi G router withinbuilt ADSL 2+ Modem.
Budget rs 4000...
It should have:
1. Good range for the whole house. Spread around 2500 sq ft.
2. Preferably a Changeable antenna as I have an antenna that can be used to increase range.
3. ADSL 2+ modem built in.
4. 4 ethernet ports.
I will hook up 2 PCs via ethernet. Am using NTC(Nepal Telecom) broadband. Will surf on my laptop as well through Wifi.
Thanks...
Bikalp Paudel
PS: Cant reply for a few days.. sorry for that.
I'm not a GEEk, i still use Windows!
bikdel is offline
Old 02-06-2008, 05:22 PM   #2 (permalink)
Living to Succeed
ajayashish's Avatar
Default Re: WIFI Router with ADSL 2+
i have Netgear Router + ADSL modem... with 4 lan ... wifi...
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 02-06-2008, 05:33 PM   #3 (permalink)
even i want 1 with the same features. there r two models which are as per the needs netgear dg834 and linksys wag200. which1 is better netgear or linksys?
raja2281 is offline
Old 02-06-2008, 05:40 PM   #4 (permalink)
Alpha Geek Banned
bikdel's Avatar
netgear models which u have doesnt have changeable antenna...
bikdel is offline
Old 02-06-2008, 05:57 PM   #5 (permalink)
Living to Succeed
ajayashish's Avatar
^^^ no it has a changable anteena
Old 02-06-2008, 06:50 PM   #6 (permalink)
Alpha Geek Banned
bikdel's Avatar
^^ can u post some pics?... or a link?
^^ can u post some pics?... or a link? I think netgear is also not good with signal reception...
hellooo.... bump....
bikdel is offline
Best ADSL 2+ WiFi Router......? abhinav_bipnesh Reviews 8 13-06-2008 10:40 AM
ADSL Router Problem bhushan05d251 Hardware Q&A 6 29-05-2008 10:11 AM
Want to buy a ADSL Modem cum Wireless Router paragkalra Networking 5 22-02-2008 02:56 AM
