Old 02-06-2008, 06:05 AM   #1 (permalink)
Mobile Freak
reddick's Avatar
Smile Suggest new PC within 30K
OK that was the budget...And wht I want is:-
AMD Processor
Any good mobo may b of 'ASUS'
Upto 2GB RAM
250 GB HDD
LCD Monitor
Good Wi-Fi card (for internet)
I have rest of the hardware...enough for my needs
I just want PC for casual gaming and net purposes
And can I gt 'Win Vista Home premium' within the described budget or I have to opt 'Home Basic' ver.
Thanks for your patience
Hope 4 d best n Do d right :)
reddick is offline
Old 02-06-2008, 10:43 AM   #2 (permalink)
paranj
Posts: n/a
Default Re: Suggest new PC within 30K
OK as per i say -
AMD x2 5600+
ASUS M2a-VM
Kingston Value RAM 2GB DDR2 667MHz
Seagate Barracuda 250GB 7200.11 HDD
ViewSonic VA1912w
Can someone suggest a wi-fi card?
I assume u dont have the graphics card. I recommand XFX 9600GT 512MB
Old 02-06-2008, 11:23 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
AMD X2 5200+ (1mb cache, 2.6GHz): Rs.4.5k
Gigabyte GA-MA78GM-S2H (latest 780G chipset, Phenom processor support, dx10 onboard graphics with 3DMark 2006 2000 marks, DDR2 1066 support, PCIe2.0, hybrid crossfire, HDMI 1.3* certification, support Full HD 1080P, Blu-ray/HD DVD Full Rate Audio Support, gigabit lan) : Rs.5,800
OCZ Value RAM DDR2 (1GB x2 KIT) : Rs.2,800 or Kingston 2x1Gb DDR2 800: Rs.2.2k
Sony or samsung DVD writer : Rs.1.2k
APC UPS: 3.2k for 650VA
Logitech wired desktop k/b andmouse: Rs.800
Dell 198WFP 19" widescreen display : Rs.9.7k
Logitech X-540 for Rs.4.5k or Creative T6060 for 3.5k
Decent cabinet that fits your budget. Rs.2k
250Gb Western Digital or Seagate SATA2 : Rs.2k
Comes to around 31k without speakers and with kingston ram.
My sincere suggestion : For good quality display, only choose among Samsung, Dell and LG. Viewsonic, AOC etc are making really bad quality panels to cut price.
If you want AMd setup, stick to the latest 7xx series mobo's coz
1) Better support for ram
2) support next gen AMD phenom quad core processor
3) add a graphics card and you can still make graphics card and onboard GPU work in crossfire mode (like they work together to produce better graphics)
4) supports FullHD unlike the older chipsets that struggles to get fullHD out of it.
But IMHO, you can try this config and it will blow away the AMD's setup:
1) Intel dual core E2180: Rs.3k
2) ASUS DG31 or GG33 based board: Rs.3.5k or Abit IP35-E for 5k
3) 2x Kingston DDR2 800 1Gb : Rs.2.2k
4) MSi NX8600GT 256Mb : Rs. 4.5k
5)250gig wd or seagate hdd: Rs.2.1k
6) Dell 198WFP 19" display: Rs.9.7k
7) APC 650VA UPS: Rs.3.2k
8) Logitech corded desktop: Rs.800
9) Sony/Samsung DVD Writer: Rs.1.2k
10) Creative T6060 or Logitech X-540: Rs.3.5k/ Rs. 4.5k
desiibond is offline
Old 02-06-2008, 11:40 AM   #4 (permalink)
You gave been GXified
gxsaurav's Avatar
Wink Re: Suggest new PC within 30K
have a look at this thread
How to make an inexpensive & efficient Computer
about.me/gxsaurav
gxsaurav is offline
Old 02-06-2008, 10:25 PM   #5 (permalink)
Comes to 10.8k after all the "additions", though a great monitor, certainly not a VFM
t3chg33k is offline
Old 02-06-2008, 10:40 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^^come on dude.
I myself bought it for 9.8k taxes included from a dealer. Do not order it online as dell charges a lot on it. Get it from a dealer. And yes, it certainly is VFM.
Old 02-06-2008, 10:51 PM   #7 (permalink)
Yes I had to quote the online price because it seems that Dell monitors are not stocked by many dealers outside of Bangalore where its offices are located.
BTW Dell also revised its non-inclusive price from 9.2k to 9.7k in the previous week.
Inflation kicking in perhaps?
t3chg33k is offline
Old 02-06-2008, 11:12 PM   #8 (permalink)
johnjjx's Avatar
For 30k get e7200 5.8k
Biostar p35 4.4k
9600gso 6.2k
Lcd dell 19 9.6k
Gskil 2gb 2.4k 250gb 2.1k
johnjjx is offline
Old 02-06-2008, 11:17 PM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^am lucky to be in Bangalore
Old 03-06-2008, 01:03 AM   #10 (permalink)
paranj
Posts: n/a
ya hehe !! Well i dont think u will get all the stuff johnjix mentioned
Old 03-06-2008, 09:09 AM   #11 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ Yes. I will. But have to preorder it.
Old 03-06-2008, 09:58 AM   #12 (permalink)
paranj
Posts: n/a
^^sure! get them! Buy 8800GTS rather that card
Old 03-06-2008, 10:39 AM   #13 (permalink)
Google Bot
Pathik's Avatar
Dude, a 8800GTS would cost about 16k.. And Desii isnt getting a config anyways. And while you are at it, Why dont you recommend a QX9650 and a Asus P5E3 premium as well?
Pathik is offline
Old 03-06-2008, 10:53 AM   #14 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Biostar p35 4.4k
9600gso 6.2k
Lcd dell 19 9.6k
perfect ..this CPU rocks..great overclocker
but get ABit IP35 for a better oc
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 03-06-2008, 11:05 AM   #15 (permalink)
paranj
Posts: n/a
@Pathik - The Google Bot
Well well i was going to say it, thanks for reminding me
Old 03-06-2008, 05:31 PM   #16 (permalink)
Mobile Freak
reddick's Avatar
Thumbs up Re: Suggest new PC within 30K
Thanks a lot dude for ur valuable replies
But no one have mentioned abt wi-fi card and wht abt OS?
I have heared abt integrated wi-fi mobo...did they worth paying?
Which OS should I go for...Here 'Win Home Premium' costs around 6K
I think it suits my needs
Also should I have to raise my budget as u guys have finish 30K within d answered Hardware stuff...Thanks for ur sugestions
reddick is offline
Old 03-06-2008, 05:44 PM   #17 (permalink)
Alter Bridge=GOD
yea get vista home premium..
at last found someone buying an OS great !
wifi - a router , linksys or netgear..hw abt it?
Old 04-06-2008, 10:13 AM   #18 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Netgear PCI Wireless Card (WG311) for 900 bucks
D-link for 1100 bucks
Have no idea how these work.
Old 04-06-2008, 12:52 PM   #19 (permalink)
paranj
Posts: n/a
Get Windows XP Pro SP3 for now i suggest. Vista sux big time
Old 06-06-2008, 09:36 PM   #20 (permalink)
Mobile Freak
reddick's Avatar
Sorry for replying late...
@paranj
I want latest windows...Vista is more safer and fast than XP...Also here 'WinXP Pro' n 'Win Vista Home Premium' cost same upto 6K...It may b diff. of 400-500 rs. only
But I can't comprmise n take risk for saving 400 bucks in the case of OS
reddick is offline
Old 06-06-2008, 10:31 PM   #21 (permalink)
johnjjx's Avatar
@nish higher yep ip35-e is best at 5.4k mre stable overclkin.
Get netgear. D-link aint tht gud.
johnjjx is offline
Suggest a PVP: around 10K napster007 QnA (read only) 7 12-05-2008 11:54 AM
Pls suggest the best LCD TFT. sysfilez Hardware Q&A 7 04-05-2008 09:49 AM
Suggest a c2d rohus24 Hardware Q&A 17 24-06-2007 06:46 PM
please suggest vijayraghavan Software Q&A 1 14-08-2006 10:44 PM
