Old 01-06-2008, 11:31 PM   #1 (permalink)
Good Boy
george101's Avatar
Default Plz Help!!!!!!!! System Not Booting!!!!
guys am having an unusual problem. i dont knw wats wrong with my pc. its not booting into wen i turn on th pc. the bios is booting but the windows isnt. not even bootable cd is booting and it gets stuck at "press any key to boot from cd"... i tries replacing the psu, hdd, etc but nothing seems to help... plz tell me wat to do?
my config is
intel C2D E6300
intel dg965ss
250gb x3 SataII Seagate
1gb x2 DDRII Ram
8600gt 256MB XFX
Samsung DVD Writer
Vista Ultimate
george101 is offline
Old 02-06-2008, 01:13 PM   #2 (permalink)
Lightbulb Re: Plz Help!!!!!!!! System Not Booting!!!!
Are u trying to boot from the OS CD?
OK forget it, Now
Reset ur bios it may solve ur problem.
How? the simple way
*remove cd from drive.
*turn off ur pc & disconnect main power cabel.
* dissconnect all power cable & data cables of all devices(inside cabinet). Do not dissconnect
24 pin power connector from MB.
*remove BIOS battery
*connect main power cable & press power button once.
* then disconnect power cable & reconnect all data & popwer cables inside
cabinet.
*connect power cabel, switch on ur pc , goto bios & configure it,
set proper 1st boot device
*save bios setting & exit(press F10).
pareshwk is offline
frustrated ! system not booting digitizen Hardware Q&A 5 23-09-2007 05:22 PM
system booting problem sanftpup Hardware Q&A 4 22-08-2007 11:20 AM
System Display goes off while booting rajivnedungadi Hardware Q&A 3 24-11-2006 01:58 AM
How To Configure My System For Dual Or Triple Booting ????? clmlbx Software Q&A 3 14-09-2006 09:19 PM
Urgent...Please help.....winxp system not booting Darthvader Software Q&A 4 08-02-2005 09:20 PM
