| Forum |
#1 (permalink) |
if some sort of speaker would be fine. thank you in advance.
|| Intel i5 2500k || Asus P8Z68-V ||Corsair HX 750 ||EVGA 9800 GTX || G-skill 4GB x 2 (1600 Mhz ) || WD 320+750+2TB Seagate Green || CM Scout || Nokia N-8, Sony Ericsson C905 both rocks my world... Last edited by heartripple; 06-06-2008 at 07:18 AM. |
#3 (permalink) |
i need a configuration.
|| Intel i5 2500k || Asus P8Z68-V ||Corsair HX 750 ||EVGA 9800 GTX || G-skill 4GB x 2 (1600 Mhz ) || WD 320+750+2TB Seagate Green || CM Scout || Nokia N-8, Sony Ericsson C905 both rocks my world... |
#4 (permalink) |
Posts: n/a
CPU + Mobo - Intel Core 2 Duo E2140 + Intel DG31PR
RAM - 1GB DDR2 667MHz Transcend RAM HDD - 160GB SATA Hitachi GPU - XFX 8400GS 128MB (can also dp without this if u just want office apps.) Case+PSU - Zebronics Krrish + Antec 450W PSU Monitor - LG E500 15" CRT Keyboard+Mouse - Odeyssey Multimedia combo Speakers - Creative SBS 245 Price with GPU will be Rs.24,000 approx And without GPU will be exactly around Rs.21,500 Might wanna add a cost of Rs.4,000 for Xp Pro or better use Ubunto 8.04 as u just need office apps and net. Use open-source instead piracy! Ask me if u have queries |
#5 (permalink) |
Unmountable Boot Volume
[quote=ketanpatel;846045]hey guys i need a computer for casual computing and some office work.
if some sort of speaker would be fine./quote] AMD Athlon X2 4200+ - Rs 2850 Asus M2MNX-SE Montherboard - Rs2600 2x512MB Transcend RAM (Only if Dual Channel required)- Rs1150 Western Digital 160GB Sata2 - Rs1850 Mercury Cabinet - Rs1400 Logitech Keyboard&Mouse Combo - Rs750 Creative SBS-370 2.1Spearker- Rs1350 LG 17" 700E CRT - Rs4550 ========================================= Total: Rs16500/- If you want to add some juice to the config add this: MSI 8600GT 256MB DDR3 - Rs3200 Dell SE198WFP 19" LCD - Rs10500 - Difference with LG CRT- Rs5950 ================================================== == Total: Rs16500 + Rs3200 + Rs5950 = Rs25650/- You make the call
Webhosting for Rs12/month!! http://www.thinkdigit.com/forum/showthread.php?t=74717 http://www.outpowerhosting.com |
#7 (permalink) |
Seems like you are an intel lover.
Teh e2140 is not better than the x2 4200+. The second problem with Intel products is that you end up having unused potential products paired up. the Processor supports only upto 800Mhz FSB and what's the point in pairing it with a board that supports 1333Mhz FSB? Essentially you're wasting your money for somethign you can't use. The motherborad costs 3750 and the M2MNX costs only 2600, and you say there is no price difference?
#9 (permalink) |
+1 for amd rig
X2 4200+ 2.8k Gigabyte 780g mbo 3k 1gb ram 1k Logitech kbd+mouse .7k Samsung sh230d 1.1k Wd 250gb 2.2k bijli cabby 1k n powersafe 400w gold 1.5k Crt 17inch 4.5k Spks vs4121 2.7k |
#11 (permalink) |
Point Blanc
+1 for amd based system, he can get 17" LCD monitor in this case,
casual computing, and sort of speaker shows he wants all his config in 22K Basic config with 17" Samsung or LG LCD monitor Altec Lansing BXR 1121 (2.1 speaker) = 1100 XFX 8400 GS 256 MB = 2100 Logitech Keboard Mouse combo = 700 17" LCD = 7500 - 8000 WD 160 GB SATA = 1800 Kingston/Transcend 1 GB = 1100 Sony DRU 190A = 1200 Cabinet = 1500 This comes to Rs 17500-18000 After this I suggest the mobo and proccy which mostly people are suggesting as above adding the budget for 5-6K making total about 23-24K because we can get a decent intel proccy and mobo cumposition as well as AMD based system. After this my suggestion would be atleast get a decent cabinet and PSU instead of normal combined PSU n cabinet spending 3K, which would make the config priced 25-26K |
#13 (permalink) |
^ya we got it. If u plan to ovr clk get e2160+biostar p35=7k. Get a gud smps nyway. Powersafe gold400 1.5k or cm 460 1.8k.
Altec lansing Vs4121 is best at 2.7k u wud luv it. Get mercury 86gt ddr3 at 3k than goin fr 84gs. U l get 2x performance. Last edited by johnjjx; 02-06-2008 at 12:45 AM. Reason: Automerged Doublepost |
#14 (permalink) | |
Point Blanc
Do not over increase his budget. Just why 2.1 speakers why not Z5500D or bose home theater audio system but I do agree 86GT ddr3 would be much more better than 8400GS just spending that 1K but besides these he really need to come up with what he wants, I see more n more people asking suggestions but after that going mum even without commenting if it was any help or how they planned out things |
#16 (permalink) |
My current PC cofigration is :
AMD ATHLON 64 x 2 4200 ASUS M2N-MX 1 GB DDR 2 667 Mhz 320 GB WESTERN DIGITAL HDD SONY DRU 170 AW DVD writer i m asking new configuration for my cousin. he just want some good expirience of computing and some office works. thanks all of you.
#17 (permalink) |
Point Blanc
we have mentioned config suitable for you, but you have not mentioned whether 22K includes monitor or its just for the CPU.
In any cases we have given a base config similar to your existing PC You can change intel config bettering the proccy and mobo if monitor is separate from the budget of 22K going for Intel C2D e7200 with any of the following mobo Intel dg33FB/DP35DPM if intel mobo is your priority Abit IP35-E or ASUS mobo suggested by my other good friends with nVidia 3500 gfx card making the cost of the above bundle as 5.5+5+3.5 = 14K |
#18 (permalink) |
now budget is extended to 37k maximum so suggest some good rig.
include lcd in this rig. and also suggest some core2 Duo based systems.
#19 (permalink) |
Posts: n/a
Hey thanks for choosing Intel budd. Anyways I sell more Intel products than their crappy salesman and ads
Intel Core 2 Duo -- E4500 Mobo - Abit IP35e RAM - 2GB Transcend DDR2 667MHz GPU - XFX 8600GT 256MB GDDR3 HDD - Seagate Barracuda 7200.10 250GB SATA Case+PSU - Case is ur choice. Get a Powersafe 500W Gold. Monitor - AOC 17" Speakers and kbd-mouse are ur choice. |
#20 (permalink) |
thanx man 1 question is in my mind should i go for e6xxx series processor.
and if possible give separate price tags.
#22 (permalink) |
thanx man
#23 (permalink) | |
The Smaller Bang
My config: Biostar TP35D2-A7 - P35 chipset (same as Abit IP35-E) - 4.5k Core2Duo E7200 - 2.53GHz, 3MB L2 Cache, 1066MHz FSB - 5.7k Transcend Value RAM DDR2 800MHz 1+1 GB Dual Channel - 1.8k nVidia 8600GT 256mb GDDR3 - 4.5K Zeberonics Bijli Cabinet - 1.5k VIP 600W SMPS - 1k Logitech R-20 2.1 Speakers - 1.2k Dell SE-198WFP 19" Widescreen 1440 x 900 monitor - 9.2k Logitech Laser Multimedia combo - multimedia Keyboard + laser mouse - 1k Samsung SH-S203B 20x DVD-RAM drive - 1.25k Seagate ST3500320AS 500GB HDD - 4.2K w00t, it managed to fit into budget and 1k is still remaining.
http://TheSmallerBang.wordpress.com eMachines E725 - T4400 2.2GHz, 1GB, 160GB Nokia 5130XM * T-Sonic 610 2GB Nokia 2323C * Samsung Galaxy Y Apple iPad 2 16GB WiFi |
#25 (permalink) | |
Alpha Geek Banned
[QUOTE=Cyrus_the_virus;846144]
u sure MSI 8600 gt ddr 3 is just 3.2 k? Bang for buck man.! What is the cheapest 8600 ddr3 in market? Other than the electric stove of course!!
I'm not a GEEk, i still use Windows! |
#26 (permalink) |
yeah sure i will celebrate it
#28 (permalink) | |
no laptop man he needs some gaming capablities so desktop is required in his case. no more suggestion
|| Intel i5 2500k || Asus P8Z68-V ||Corsair HX 750 ||EVGA 9800 GTX || G-skill 4GB x 2 (1600 Mhz ) || WD 320+750+2TB Seagate Green || CM Scout || Nokia N-8, Sony Ericsson C905 both rocks my world... Last edited by heartripple; 07-06-2008 at 09:22 AM. Reason: Automerged Doublepost |
#29 (permalink) |
no more suggestiions
#30 (permalink) |
Jai Suresh
Gigabyte GA-MA78GM-S2H - 4700
AMD X2 - 5200+ DUAL Core - 4950 Cabinet with SMPS - 2700 Seagate 360GB - SATA 32 MB Cache - 3500 1GB DDR2 RAM x 2 800 MHz - 2400 DVD Writer - 1500 Samsung 17'' LCD 732NW Wide Screen - 8700 KB+Mouse - 1800 Comes to about 30,250/- With remaining bucks get an UPS and and speakers. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
