Old 01-06-2008, 08:12 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Internal or external TV Tuner Card?
I am planning to buy a TV Tuner Card, mainly to record few programs occasionally (TV is placed right next to the computer).
For this purpose, would it be a good idea to go for an internal TV Tuner Card or an external TV Tuner Box?
Also in case any one has any recommendations, then please let me know.
http://www.yogeshsarkar.com
Yogesh Sarkar is offline
Old 01-06-2008, 09:09 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Internal or external TV Tuner Card?
Go for internal tv tuner card as they arey gives unmatched performance while recording.
Look for brands like leadtek or pinnacle.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 02-06-2008, 11:51 AM   #3 (permalink)
15.0 GHz
VarDOS's Avatar
Go For Internal TV Tuner Card With Recorder And A Wide Screen Support.
VarDOS is offline
Old 02-06-2008, 12:36 PM   #4 (permalink)
Thanks Top Gear any idea how much a TV Tuner Card from Leadtek would cost?
Thanks Varad, any particular recommendation?
Old 02-06-2008, 01:16 PM   #5 (permalink)
15.0 GHz
VarDOS's Avatar
Sorry I Have No Idea About Its Cost
Take A TV Tuner Card Which Will Give Support To DishTV,Tata Sky And Others
VarDOS is offline
Old 02-06-2008, 07:58 PM   #6 (permalink)
I don't think I'll need DishTV o Tata Sky support because I don't have them right now and don't see myself using them in near future.
Old 02-06-2008, 11:30 PM   #7 (permalink)
99.9% Idle
axxo's Avatar
go for WinFast TV2000XP Global retails around 2.4k
axxo is offline
Old 03-06-2008, 05:21 AM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
I would recommend Leadtek WinFast DTV1800 H which should be around Rs. 3000-3500.
topgear is offline
Old 03-06-2008, 10:56 AM   #9 (permalink)
15.0 GHz
VarDOS's Avatar
I Think You Should Go For Pinnacle Systems TV Tuner.
VarDOS is offline
Old 03-06-2008, 12:30 PM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
ya , As far as tv tuner card concerned pinnacle is the best.
To get a idea about prices check out this website :
http://www.theitwares.com/tvtuners/tvtuners.htm
topgear is offline
Old 03-06-2008, 08:35 PM   #11 (permalink)
Yup Pinnacle is good, however spending 3-4k for something I am only going to use maybe once or twice a month is something that I am a bit apprehensive about.
Old 04-06-2008, 12:49 PM   #12 (permalink)
Fast 'N' Furious
topgear's Avatar
Go to
Find something that fits your choice or go for waht axxo suggested. But Leadtek WinFast DTV1800 H
is a real master piece considering the features & prove it's worth in long run. You won't be disappointed.
topgear is offline
Old 05-10-2008, 03:20 PM   #13 (permalink)
Guys where in India (Delhi) can I buy Leadtek Tv tuner cards??
Any dealer in NP or online.
ranjan2001 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/89375-internal-external-tv-tuner-card.html
Which TV to Computer device is better: TV Tuner Cards or external USB Tuners? This thread Refback 24-06-2010 04:09 PM
External or Internal TV tuner? sabret00the Hardware Q&A 38 17-05-2007 01:57 AM
internal tv tuner card reddevil2 Hardware Q&A 1 13-12-2005 10:40 PM
