Old 01-06-2008, 12:31 PM   #1 (permalink)
The Last Puff
Artemis's Avatar
Default My first Case Mod
This is my first case mod, decided after thinking about it for quite a while, actually 6 months, finally!!
I'm posting the pics, all suggestions are welcome
This is my shitty old cabinet, it hurts my eye just to see it...
I have decided to strip off the aluminum covers of the cabinet and replace it with wood, the interior painted black and a plexiglass panel on the right side panel as a seethru
Music is the opiate of life and I’m stoned all the time.
MacBook Pro 13”
Aural Nirvana : Audio Technica CK10 | Panasonic RP-HJE900 | Alessandro MS-1
http://www.last.fm/user/rotter2142
Artemis is offline
Old 01-06-2008, 12:59 PM   #2 (permalink)
paranj
Posts: n/a
Default Re: My first Case Mod
lol u shud have gotten urself a CoolerMaster or Nemesis cabinet! BUT the effort u did is awesome man. Thinking too abt modding my case, any tips?
Old 01-06-2008, 01:12 PM   #3 (permalink)
The Last Puff
Artemis's Avatar
the design is something diff. couldnt do it on paint, will upload it later, its with more curves
I had bought it abt 5 yrs before, didnt hav dat much knowhow then..
b4 starting plan it out, u dont want to be hung up, modding depends on ur budget, wat u want depends entirely on u, wood, complet glass
just cutting up ur sidepanel is too n00b-ish
should i paint my smps black too???
coz the it will be seen thru the side panel, worried about the warranty though
what shuld i do??
MacBook Pro 13”
Artemis is offline
Old 01-06-2008, 01:24 PM   #4 (permalink)
Point Blanc
editted my post checking you say flexi glass, hmm good option,
I hope you also would be thinking of giving cuts in between for better ventilation,
also what is your location, any helps on where are you getting flexi glass and how you are getting them cut for your case moddingand thickness of wood you decided on putting there.
acewin is offline
Old 01-06-2008, 01:37 PM   #5 (permalink)
The Last Puff
Artemis's Avatar
my bad, its actually plexiglass, i'm in ahmedabad, but brought the glass from Mumbai
I did most of my shopping from there, the fan grills, case fans, wasn't sure of getting it here... though i still couldnt get 12" col cathode blue case lights, still dont know where to get them
I hav bought a 4mm plexiglass 17"x22" for 100 bucks, and deciding to use 12mm ply or MDF, though mdf is a better option(lighter), i'll hav to buy a 8x4ft. sheet costing 900rs. only a quarter of it will be used
u will have to checkout ur nieghbourhood glass store, they will cut it out 4 u
which one of the designs should i use on the MDF side panel?? i'm going to cut it out in the middle and fix a plexiglass there as a seethru, and fit a 120mm fan thereon the glass
MacBook Pro 13”
Artemis is offline
Old 03-06-2008, 11:08 PM   #6 (permalink)
The Last Puff
Artemis's Avatar
Will get the wood work ready by tomorrow...
I need some help, where can I get 12" ccfl pc kits in Ahmedabad or off the net???
can't seem to get one here??? no international shipping plz coz they'll rip me alive!!!!
MacBook Pro 13”
Artemis is offline
Old 04-06-2008, 02:34 AM   #7 (permalink)
Seed is the Life!!
shift's Avatar
great work!
why not use Paint Spray ? the finishing is better than brush painting
guys, any idea where i can get col cathode blue case lights in bangalore?
Stupidity Causes Cancer !!
shift is offline
Old 04-06-2008, 02:49 AM   #8 (permalink)
No pain....No gain
john_the_ultimate's Avatar
@Artemis and shift
You'll get the CCFL's here http://www.primeabgb.com/index.php?o...d=50&Itemid=28
BTW, Artemis nice work, keep it up. And yes try using spray paint you'll get a better finish.
If you are ready for international shipping then check this www.sidewindercomputers.com It's a great place to shop and the owner Gary is really a nice guy.
john_the_ultimate is offline
Old 04-06-2008, 01:01 PM   #9 (permalink)
paranj
Posts: n/a
woooo man. its a lot of work. m going to ebay or sumthing and ordering a CoolerMaster case. I cant do all this , i m lazy
Old 04-06-2008, 11:40 PM   #10 (permalink)
The Last Puff
Artemis's Avatar
Originally Posted by john_the_ultimate View Post
@Artemis and shift
how much will a paint spray cost me???
MacBook Pro 13”
Artemis is offline
Old 05-06-2008, 02:21 AM   #11 (permalink)
No pain....No gain
Around Rs.150-250 (150ml) depending on the quality.
Old 05-06-2008, 08:53 AM   #12 (permalink)
paranj
Posts: n/a
Rs.375 for a 250Ml can here for a local brand
Old 05-06-2008, 09:16 PM   #13 (permalink)
The Last Puff
Artemis's Avatar
My wood panels, with the primer applied on...
MacBook Pro 13”
Artemis is offline
Old 06-06-2008, 09:56 AM   #14 (permalink)
Seed is the Life!!
shift's Avatar
my custom made rounded ide cable
look cool with neon light and with see thru side glass (plexi glass)
(neon was off while taking dis pic)
http://img75.imageshack.us/img75/3301/12ey5.jpg
shift is offline
Old 06-06-2008, 10:02 AM   #15 (permalink)
paranj
Posts: n/a
i need a CoolerMaster case. Recommand me one please!
Old 06-06-2008, 10:22 AM   #16 (permalink)
No pain....No gain
@paranj
Budget?
You can the look for the tried and tested CM690 for 4.2k.
Old 06-06-2008, 10:28 AM   #17 (permalink)
paranj
Posts: n/a
5k
Old 06-06-2008, 10:32 AM   #18 (permalink)
No pain....No gain
Then CM690 is perfect and you do have the option to take with or without transparent side panel.
Old 06-06-2008, 10:36 AM   #19 (permalink)
paranj
Posts: n/a
thanks. need to find it in my city somewhere
Old 06-06-2008, 12:57 PM   #20 (permalink)
Google Bot
Pathik's Avatar
+1 for the CM 690. You can get it shipped too.
@John, Artemis which toolkit do you use to cut metal?
Pathik is offline
Old 06-06-2008, 12:58 PM   #21 (permalink)
paranj
Posts: n/a
^^ChainSaw
Old 06-06-2008, 03:37 PM   #22 (permalink)
No pain....No gain
Chainsaw
@pathik
Donno about Artemis but I used DREMEL for cutting purpose. And few pieces of heavy duty double sided tapes for the arcylic window.
Old 06-06-2008, 05:44 PM   #23 (permalink)
The Last Puff
Artemis's Avatar
I think i have a problem here, the front panel has lines on it and they are visible like hell, though not from a distance, is there any way around it???
How do i make holes in my 5mm acrylic sheet for fitting the fan on it?
@Pathik I used a dremel to cut the plates...
Also i need to stick my Fan on the top panel so what should i use? Heard that fevikwik will melt its body, need something that becomes transparent after drying up, any suggestions???
Also are fan vibration dampeners really needed?? It just doesn't justify its price...
Is there any method to build them on their own??
Is that gelatin paper or the UV wrap cables??? need to know, coz i am also thinking about it
MacBook Pro 13”
Artemis is offline
Old 06-06-2008, 06:24 PM   #24 (permalink)
Google Bot
Pathik's Avatar
Try transparent screws. BTW for how much did you guys get your Dremel?
Pathik is offline
Old 06-06-2008, 06:31 PM   #25 (permalink)
The Last Puff
Artemis's Avatar
I just borrowed it from my neighborhood carpenter, ask your 'mistry' if he could give it to you for an hour or so
I'll make myself clear, i need to make the fan fit snugly in b/w the hole of the top panel so using screw's is out of question, i need a glue that becomes transparent, i need to know its retail name...
MacBook Pro 13”
Artemis is offline
Old 06-06-2008, 10:57 PM   #26 (permalink)
No pain....No gain
Superglue maybe. For the front panel use some paper/wood based pudding then sand out the excess so that you get a smooth surface.
@pathik
Got this set from US but a similar product is available in india through telebrands.
http://www.telebrandsindia.com/Teleb...0Rotomatic.asp
Old 07-06-2008, 04:24 AM   #27 (permalink)
The Last Puff
Artemis's Avatar
This is the final coat...
The backside of the panels:
Expecting my CCFl delivery tomorrow, hopefully this is going to be over by sunday...
MacBook Pro 13”
Artemis is offline
Old 07-06-2008, 04:35 AM   #28 (permalink)
Seed is the Life!!
shift's Avatar
its actually a black polythene
wrapped with transparent tape
if u are not using LED fan or something blue color like neon to give light to your cabinet, dont use it.......
looks cool only under blue light....
shift is offline
Old 07-06-2008, 04:51 AM   #29 (permalink)
The Last Puff
Artemis's Avatar
@shift well coincidentally i'm adding both, but there's a doubt on how it looks,
could u please send me a picture of how does it look in the neon light...
MacBook Pro 13”
Artemis is offline
Old 07-06-2008, 07:24 AM   #30 (permalink)
johnjjx's Avatar
Great work goin on. Junkies
johnjjx is offline
All About Case Fan Revolution Hardware Q&A 1 08-04-2008 09:02 AM
usb case for HDD reddevil2 Hardware Q&A 4 28-01-2007 08:47 AM
PC case jatinkompelli Hardware Q&A 8 31-08-2006 05:45 PM
CPU Case Mod.. dreams Hardware Q&A 5 09-12-2005 07:14 AM
should we get a dvd case anirudh QnA (read only) 9 29-10-2004 05:11 PM
