Old 07-06-2008, 08:17 AM   #31 (permalink)
No longer here..
Default Re: My first Case Mod
For the lines to make them dissappear you can use "rubbing compound".Its a kind of polish auto repair works use to produce a glossy shine on the painted surface.Its a abrasive (a very fine one) which chips away the small amounts of paint and will produce a nice even shiny surface.But dont overdo it on one place other the paint will wear down to the lower level.
For making holes in the acrylic you can use a 5 mm drill ....
Nice modding there by the way ..
indian_samosa is offline
Old 07-06-2008, 12:12 PM   #32 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Gr8 Goin Buddy !
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 08-06-2008, 05:04 AM   #33 (permalink)
The Last Puff
Artemis's Avatar
Got my finger 'superglued' to the fan, at midnight had no nail polish remover, got a scolding from my parents for doing "TodPhod" and to get things straight by today... hopefully
The side panel shown here doesnt fit coz the fan and the smps clash with each other obstructing the sliding of the side panel in its locks...
Will have to buy a new acrylic sheet and set things straight, Also planning to buy a DVD writer coz my old ones gone kapput, any one that is recommended other than Lite-On LH20A1P???
P.S.:- Cable management needs to be done
@shift
thanks for the idea, though i used a 'blackish' gelatin paper, planning to do it everywhere inside
one more question, for the round ide part, after cutting it up instead of using the black paper can i colour it black??? will it look nice?
Music is the opiate of life and I’m stoned all the time.
MacBook Pro 13”
Aural Nirvana : Audio Technica CK10:-D | Panasonic RP-HJE900 | Alessandro MS-1
Last.fm
Artemis is offline
Old 09-06-2008, 02:21 AM   #34 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Remove the foam from behind the mobo, it may cause overheating of the components. Anyways, great work there and the cabby looks cool.
john_the_ultimate is offline
Old 09-06-2008, 02:33 AM   #35 (permalink)
The Last Puff
Artemis's Avatar
yeah i'll do that, though had it on for like 4 years
MacBook Pro 13”
Last.fm
Artemis is offline
Old 09-06-2008, 03:31 AM   #36 (permalink)
johnjjx's Avatar
Nice goin buddy. U can do sme graffiti too
johnjjx is offline
Old 09-06-2008, 04:02 AM   #37 (permalink)
looks cool put on some stripes or designs.
atish is offline
Old 09-06-2008, 06:50 AM   #38 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Good Work, could have improved on finishing but for the started, its off the hook! Keep the good work.
keith_j_snyder2 is offline
Old 09-06-2008, 11:33 AM   #39 (permalink)
Gr8 Final Product ...
Old 10-06-2008, 02:19 AM   #40 (permalink)
The Last Puff
Artemis's Avatar
This is the final thing sans the writer,graphics card and the RAM,and the back side panel...
with the blue neon lights off:-
Also for the design i have thought about it and decided to make stripes on it a la Dodge Viper but i don't know what colour, black or dark blue???? the stripes will be running from the front panel to the spine of the top panel???? whatsay... really need to know am confused!!!!!!!
MacBook Pro 13”
Last.fm
Artemis is offline
Old 10-06-2008, 03:37 PM   #41 (permalink)
Point Blanc
so finally you got it in finish mode good going buddy
acewin is offline
Old 10-06-2008, 04:32 PM   #42 (permalink)
good job buddy!!
liked it...
mastermunj is offline
Old 14-06-2008, 01:43 AM   #43 (permalink)
Techie By Heart
mavihs's Avatar
wow!!! nice!!! even i'm thinking to mod mine!! any advice???
Modding My Cabbie!! ! ! !
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline
Old 14-06-2008, 03:39 AM   #44 (permalink)
johnjjx's Avatar
good work bro.....didnt like d color much but will do....
e8400 / abit ip35-E / gskill 4gb / mx5021 + audigy 2zs / Visiontek 4870 / corsair vx450 / Dell E198wfp
johnjjx is offline
Old 14-06-2008, 03:52 AM   #45 (permalink)
a_g = JPKN
s18000rpm's Avatar
the cabby's colour reminds me of Lamborghini Gallardo
sticker it with lambo logo & then it becomes your Lambo branded PC (like ASUS Lamborghini VX2).
------edit-----
this colour reinds me of tata sumo grande too
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 14-06-2008, 05:54 PM   #46 (permalink)
Super Moderator
asingh's Avatar
Wow...great work..! look good
asingh is offline
All About Case Fan Revolution Hardware Q&A 1 08-04-2008 09:02 AM
usb case for HDD reddevil2 Hardware Q&A 4 28-01-2007 08:47 AM
PC case jatinkompelli Hardware Q&A 8 31-08-2006 05:45 PM
CPU Case Mod.. dreams Hardware Q&A 5 09-12-2005 07:14 AM
should we get a dvd case anirudh QnA (read only) 9 29-10-2004 05:11 PM
