| Forum |
#1 (permalink) |
It is nice .........except for double boot.(BIOS 15) Problem 1 For Power LED it has 1-0-1 pin My cabinet has 1-1-0 pin for Power LED. It does not work. Solution ?? Problem 2 ?? CPU temp 45C System temp 39C Are these OK or Normal ( No OC done ) Speedfan readings, BIOS gives higher temps. Problem 3 I have a iBall WindowsX cabinet. This has a funnel on side panel above CPU HSF. Can I install a fan here? exhaust or intake ? My chassis fan (exhaust) has a molex power pin, so it is naturally not being controlled, being powered by PSU directly. Any solution ? Maybe I can change it? Suggest good fans......where to buy. SORRY for a longish post. |
#2 (permalink) |
At Hell's Disq
cud u post pics of ur cabby pwr led connector.
wat procy do u hav?mobo temps r ok
i7 930 @ 4.5GHz on CM N620 | BIG BANG XPOWER | 3*1GB 1333MHz | GTX 470 | 500GB + 320GB | HAF 922 | Silent Pro M 850W | MX3200 Laser | LG LD460 32" fullHD LCD TV | HP DV6 1211AX[/I][/B] |
#3 (permalink) | |
BIOS temp CPU temp 51C Sys Temp 35C PWM temp 43C CPU Fan 2481rpm I boot and Speedfan reading Sys temp 36C CPU 42C AUX 47C Temp1 50C* Core0 39C Core1 42C Core 60C* CPU Fan0 1223rpm* These * are the worry, also the BIOS discrepancy in temp. regards |
#4 (permalink) |
Alter Bridge=GOD
sometimes these programs give a wrong reading too.. i've found bios temp to be much more accurate..
try using coretemp or rrealtemp still temps are ok..
Apple Macbook Pro 17 |
#5 (permalink) |
At Hell's Disq
disable the abit EQ fan control in Bios.ur cpu fan will run at full speed.
#6 (permalink) | |
What would be good temps for E2180 with stock cooler ?
That is the question I want answered Quote:
Intel says fan goes to full speed only after CPU temp to 75C. http://www.intel.com/support/motherb.../CS-012552.htm I went through this article very briefly Last edited by Ranjya; 01-06-2008 at 10:56 PM. Reason: Automerged Doublepost |
#7 (permalink) |
At Hell's Disq
i always run the fan at full speed.keeps procy cooler.
#8 (permalink) |
Alter Bridge=GOD
normal temps are 45-60
and the side fan should blow air inside the cabinet.u should put a fan there no need to run proccy fan at 100% unless u overclock
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Abit IP35-E | Ranjya | Hardware Q&A | 3 | 20-05-2008 04:56 PM |
| Overclocking abit ip35 | ionicsachin | Overclocking | 17 | 10-04-2008 12:29 AM |
| abit ip35-e or msi neo2-fr | ionicsachin | Hardware Q&A | 14 | 28-03-2008 12:06 AM |
| ABit IP35-E | parimal | Hardware Q&A | 2 | 21-02-2008 10:13 AM |
| Quick Look at ABiT IP35-Pro | Choto Cheeta | Reviews | 12 | 11-02-2008 01:17 AM |
