Old 30-05-2008, 02:25 PM   #1 (permalink)
Default A Budget Motherboard for gaming & HDTV
Im gonna get a quad core Q6600 and most probably a eVGA 9600 GT.
Im looking at cheap motherboards about 5k as this combo already costs like 20k. I dont need on board graphics but i need 7.1 HD audio.
Ill also mostly get a LCD with HDMI input so do i need a motherboard with HD port like ABit I-N73HD (the problem here with 630i based mobo is that they only have single channel memory) or can i use the graphics card for HDMI ?? IM little confused about this..
How is Palit p35a ? Its really cheap but i cant find any reviews.
Other option is Abit IP35 which i guess is good enough. But what about HD?
rdkll is offline
Old 30-05-2008, 06:28 PM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Default Re: A Budget Motherboard for gaming & HDTV
When you go for a monitor with HDMI Port, IMHO the cost will be very huge.
Instead go for a graphics card with HDMI Port and buy a monitor with DVI-D Port.Buy a HDMI to DIV-D connector and inter connect them.
techtronic is offline
Old 30-05-2008, 11:20 PM   #3 (permalink)
moshel's Avatar
the only monitor i have come across with HDMI port is SP2208wfp from dell. its got good reviews and costs 15-17k.
budget mobo?? go for the p35 based chipset. its good dont worry. although not sure abt the 7.1 audio.
moshel is offline
Old 30-05-2008, 11:33 PM   #4 (permalink)
Try me
shantanu's Avatar
budget mobo cannot be for gaming, but a good mobo should atleast support all latest config and should be FULL ATX..
Forum rules:
http://www.thinkdigit.com/forum/announcement.php?f=3
Blog at : http://thecomputernext.com/blog
shantanu is online now
Old 30-05-2008, 11:38 PM   #5 (permalink)
j1n M@tt's Avatar
get Abit P35-E......and ur 9600GT with handle ur HD needs
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 31-05-2008, 12:35 AM   #6 (permalink)
dOm1naTOr's Avatar
I think HD 3850 or 3870 will be better for HDTV. it has got better HD decoding nd features. And also got HDMI with support for 7.1 digital audio integrated, which nvidia lacks.
Even if some manufactureres were able to convert DVI to HDMI, there is no audio o/p for nvidia cards.
u cant use onboard HDMI if u use a card. The card ned to have HD decoding nd HDMI port. Almost 90% of ATI's HD 3850/70 cards comes with HDMI adapter[but no cable which will cost u ,in of 2.5k for an avg quality one]
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 02-06-2008, 12:59 PM   #7 (permalink)
Yea i was talking about the Dell SP2208. My friend works for them so i might get a discount. So the palit P35 is good enough? If i can use the 9600GT for HD ill go for a cheaper LCD and get a HDMI - DVI converter.. There's no loss of quality in doing this right?
Sry i wasnt looking at at my thread past few days, but thanks to you all for your replies.
rdkll is offline
Gaming Laptop of 1lac budget arnold991 Hardware Q&A 6 23-01-2008 12:55 PM
Suggest Gaming PC configuration budget 75k MaxBombay PC Components / Configurations 5 31-01-2007 03:15 AM
THE BEST BUDGET GAMING PC gr8prash QnA (read only) 11 11-09-2004 08:37 PM
