Old 30-05-2008, 12:48 PM   #1 (permalink)
Default Ups problem
Hi
recently bought a new rig. i tred connecting to my existing UPS (APC around 1900Rs)
but it is having some problem it beeps as soon as i switch on my new machine (Obviously it is too much for it)
can you suggest me a new UPS which will support both my pC woth out a problem
i use Coolmaster 620W for my new machine my old one is simple mercury PSU.Thanks
sudhir31 is offline
Old 30-05-2008, 12:50 PM   #2 (permalink)
paranj
Posts: n/a
Default Re: Ups problem
iBall Nirantar ??
Old 30-05-2008, 06:39 PM   #3 (permalink)
I Always Prefer 1080p
techtronic's Avatar
1 Volt Amps (UPS) = 0.6 Watts (SMPS)
Please use this calculation to buy a UPS.
Example, a 450W SMPS would require a 750 VA SMPS
techtronic is offline
Old 03-06-2008, 03:11 PM   #4 (permalink)
Thanks techtronic
i use a 600w as i mentioned an am planing to buy 1kva or 1.5kva UPS (just in case)
i was able to find APC BR-1500 IN which is around 11k
any more suggestions
sudhir31 is offline
Old 03-06-2008, 04:02 PM   #5 (permalink)
At Hell's Disq
hellgate's Avatar
wats ur system config?
hellgate is offline
Old 03-06-2008, 05:43 PM   #6 (permalink)
E8400
Asus P5KC
PNY 8800GTS 640MB
Creative Sound Blaster X-Fi Xtreme Gamer Fatal1ty
Coolmaster extreme power 600W
seagate 320gb
sony DVD writer
sudhir31 is offline
Old 03-06-2008, 07:16 PM   #7 (permalink)
At Hell's Disq
hellgate's Avatar
u can buy the PowerCom 1kVA ups whihc i'm using for 5.8k.it also has option for xternal battery.using it 4 like 5-6months and no probs as of now.get backup of 20mins.presently posting this from ups backup.....
hellgate is offline
Old 03-06-2008, 11:44 PM   #8 (permalink)
well if you want a 1kva one, you can buy one if you afford it in the case of APC. However the powercom 1kva one mentioned above is cheaper than the APC 800VA one if im not wrong
but it depends on how long a backup time you wanted it to be.
i have corsair hx620 620W and runs fine on the APC 800VA.
of course as soon as load shedding occurred, i saved everything i m working on and shut down. so if you like me also intend to do this. doesnt need to go high. but 1kva could be more future proof incase you wanted to upgrade to a higher rated power supply..in the not so distant future we will be talking in kva terms with regard to the power supply unit of the PC..it will become very common.. when that time comes for you, u dont need to buy a new ups. so might be wise to go for a 1kva one if you can afford it now. havent use brand other than apc so is in no position to comment on the others
Q6600 | p5n32e-sli | 2x1gb Kingston ddr2800 |2x250gb seagate hdd | sony dru-190A | creative sb audigy2 zs | xfx 8800gt | corsair hx-620 | antec 900 | Ms basic desktop 500 | logitech z2300 | apc 800va
realdan is offline
Old 04-06-2008, 04:42 AM   #9 (permalink)
techtronic's Avatar
You can also opt for Microtek 1 KVA UPS which comes with a 2 years warranty
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
