| Forum |
#6 (permalink) |
Make sure u get the IDE one.
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. |
#8 (permalink) |
its the model name
7200.11 32MB 7200 is rpm nd 32 is the buffer
#12 (permalink) | |
yeah 500 Gb would be fine check this for more price info http://theitwares.com/hdd/hdd.htm |
#13 (permalink) |
yes ill have to buy ide only.
does ide to sata converters work on this mobo.anyone got any xperience?
techtricks.co.in portforwarding xp-vista crossover connection installing xp on vista notebooks |
#16 (permalink) |
is it worth going for a sata to ide converter ??
or shall i buy the regular ide.the problem is i am not going to upgrade my mobo for another 2 years(unless it stops working). will i get good mobo's with ide channel on it so tht new ide hdd can be used w/o going for hdd upgrade again? speed issues?? pls reply fast!
#18 (permalink) | |
Alter Bridge=GOD
else go with WD IDE hard drive..but make sure u go with a WD..
Apple Macbook Pro 17 |
#19 (permalink) | |
and if i remember i got 2 pci slots one is occupied by 56k modem (which i am not using)other is temporarily empty(will be used up by ethernet card )
techtricks.co.in portforwarding xp-vista crossover connection installing xp on vista notebooks Last edited by sreenidhi88; 03-06-2008 at 03:40 PM. |
#20 (permalink) |
thank you very much for the support guys.
i decided to buy 250 gb hdd initially.today i went to sp road ,asked for 250 gb wd ide hdd in one store called sahara .he offered it for 2675+tax.but he didnt have wd so went to golchha intertrade ,he also didnt have wd 250 gb hdd.infact he didnt have any internal hard disk except seagate.he offered 320 gb for 2900+tax=3016,paid 3000. 5 YR WARRANTY. so finally bought seagate baracuda 7200.1 ST3320620A.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| all files from IDE hard disk with windows 2000 to SATA II hard disk with windows | jagadish2005 | Software Q&A | 8 | 10-04-2007 11:08 AM |
| internal hard drive upgrade for laptop | sachin_libra | Hardware Q&A | 1 | 30-01-2007 01:30 PM |
| Suggest good hard disk enclosures!! | anispace | Hardware Q&A | 2 | 30-08-2006 01:04 PM |
| 80GB hard disk converted into 10780 MB hard disk | ssingha | QnA (read only) | 12 | 24-08-2004 11:57 AM |
