| Forum |
#2 (permalink) |
No pain....No gain
CM690 for 4-4.2k
--------------------------------------------------- Faith is the boast of a man who is too lazy to investigate. --------------------------------------------------- |
#4 (permalink) |
Living to Succeed
dont go for 690 as then u will not save much for PSU... better get a HX450 Corsair PSU or CM 500Watts PSU and go for CM330 or Zebronics Antibiotis cabinet
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690 & Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz |
#5 (permalink) |
CoolerMaster RC690 CM 690 4000Rs
CoolerMaster RP-600-PCAR Extreme Power 600W 3150Rs total 7150 seems fine to me http://theitwares.com/index.htm i'll check the price of my local store. thanks for advice |
#7 (permalink) |
thanks for advice i'll check them too
I like Bijli and Rage(220mm fan nice wonder whats its rpm's) bijli is priced at 1550rs with 400watt psu(i don't need it already hav 2 spare). whats the price of Rage? I can't find much pics of Zebronics cabinets. Last edited by kuki_295; 29-05-2008 at 01:55 PM. Reason: Automerged Doublepost |
#8 (permalink) |
No pain....No gain
You have a budget of 7-8k so just get CM690 (4k) + Corsair VX450W (3.5k). CM690 is much more spacious than any of those zebronics cabby. I am using this combo.
I have used zebronics peace & antibiotic cabby but this is far superior to them. Also you do get CM690 with transparent side panel.
#9 (permalink) |
The Smaller Bang
Zeberonics Gaming Series Bijli Cabinet
RS. 1,500/- the best looker around. Its still awssome looking, after all these years. All the guys I know who have it swear that nothing looks better than it. I myself have seen one in action and can confirm that.(it even has a temperature indicator...) Cooler Master 600W PSU Rs. 3,000/- take any model under 3k. It should be fine. Cooler Master F2 CPU Cooling System Rs. 2,000/- put the rest of the money on cooling the C2Q so that you can OC it a bit more. Some extra fans for the cabinet <remaining cash> put all remaining cash to get some better fans onto the system OR... get a VIP 600W PSU or something similar thats cheaper and invest the ~5k you saved on a passive cooling system to keep the noise low.
http://TheSmallerBang.wordpress.com eMachines E725 - T4400 2.2GHz, 1GB, 160GB Nokia 5130XM * T-Sonic 610 2GB Nokia 2323C * Samsung Galaxy Y Apple iPad 2 16GB WiFi |
#10 (permalink) |
thanks for info and advice
bijli has been priced well but i don't know about its features like CM690 has - 1. side HDD bay 2. fans all over(behind the mobo,2front,2rear,2up) 3.Pins to hold wire but i can't find any pics of bijli |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Need Cabinet+PSU 4K | Revolution | Hardware Q&A | 2 | 16-03-2008 09:29 AM |
| need help regarding Cabinet | nd4spd | Hardware Q&A | 11 | 02-04-2006 07:58 PM |
| which Cabinet to buy... | jay4u | Hardware Q&A | 59 | 21-03-2006 02:43 PM |
| GFX,DVD,cabinet and PSU : Help me plz... | Monster_AMD | QnA (read only) | 5 | 10-06-2005 11:56 AM |
| which of the following Cabinet u like??? | [flAsh] | Software Q&A | 17 | 28-05-2005 07:28 AM |
