| Forum |
#1 (permalink) |
PSN~ftw
so hes getting around 40-39c under no load for cpu PLEASE TELL ME IF ITS KK? |
#2 (permalink) |
well, if you are getting heat problems or in future if you are planning to use your pc for gamming as well multimedia then you sud get one.
if not there is no reason for the same, it will work fine without CM. if you think coolermaster is requirement of yours then go to www.coolermaster get the products specification before you get blast in your pocket. |
#3 (permalink) |
Rising ApocalypsE
Tell him to use Arctic Silver 5, or AC MX-2 or any good quality thermal paste.
It will cost same or more than he spend on cooler but it will be worthy!
AMD Athlon 3200+,MSI RS482M4-ILD,Kingston KVR 512MB 400,Gainward 6800GS 256MB,250GB WD Caviar,Cooler Master 430Watts. |
#5 (permalink) |
iL6>Tushar
first try to reinstall heat sink make sure properly sitted on CPU (dont apply excess thermal paste) using good thermal compound like arctic MX-2 you can buy it from www.primeabgb.com.If heating issue not solved then go for new Thermalright ultra 120 extreme or zalman cpu cooler or noctua apply thermal compound as suggested before buying check requiremt like cabinet etc.
#6 (permalink) | |
At Hell's Disq
just wake up.
i7 930 @ 4.5GHz on CM N620 | BIG BANG XPOWER | 3*1GB 1333MHz | GTX 470 | 500GB + 320GB | HAF 922 | Silent Pro M 850W | MX3200 Laser | LG LD460 32" fullHD LCD TV | HP DV6 1211AX[/I][/B] |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| CPU temperature 99 deg | risqer | CPU / Motherboards | 20 | 05-09-2007 12:55 PM |
| Is this temperature OK? | phreak0ut | Hardware Q&A | 11 | 25-03-2007 02:31 PM |
| How Do i check ram? .. Is software to check ram like Scan Disk etc. !! | rollcage | Hardware Q&A | 3 | 03-06-2006 10:16 AM |
| Max Temperature for HDD | adorablesrini | QnA (read only) | 8 | 13-02-2005 05:18 PM |
| CPU temperature | sohin | CPU / Motherboards | 6 | 11-10-2004 11:17 AM |
