Old 29-05-2008, 12:24 AM   #1 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default DVD writer needed
Hey guys i have a HP DVD writer but i need another DVD writer which can handle a bit of heavy DVD writing ......like 5 to 10 DVDs within 2 hrs of time..........
My writer is fine with it but then sometimes it turns out a dvd with some error....may be one in 20 pieces......but still i guess i am better off with something more reliable.
Money no barrier but don go beyond 2.5K
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is online now
Old 29-05-2008, 02:17 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: DVD writer needed
Get two Samsung SH S223F's
Pathik is offline
Old 29-05-2008, 02:30 AM   #3 (permalink)
i think LG may also work
get some good stuff in it depending upon ur use
http://thenamemanish.blogspot.com/
mind021 is offline
Old 29-05-2008, 07:59 AM   #4 (permalink)
sonicspeed's Avatar
sir try ASUS,Pioneer. i heard that they have the better built quality than others.
sonicspeed is offline
Old 29-05-2008, 06:39 PM   #5 (permalink)
OKie thanks for the suggestions....can anyone tel me the street prices??????
Sony Vaio CW26FG
Old 29-05-2008, 07:00 PM   #6 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
^^ romeo, your dvd quality is also important! If you want the best writing experience get original media! And I heard pioneer is quite good, but please dont go for sony.
dheeraj_kumar is offline
Old 29-05-2008, 07:24 PM   #7 (permalink)
Better go for SONY...The only problem with this is it can't read the scratched cd/dvd's....Except that, it's really awesome...
madhusoodan is offline
Old 29-05-2008, 09:49 PM   #8 (permalink)
^^ sony drives are not at all recommended. Trust me, I have one. If its a sony rebranded nec/optiarc drive, then you better hold on to your warranty tightly, if you know what I mean. I have already got it replaced once.
Old 29-05-2008, 10:21 PM   #9 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Samsung is the way to go these days
kalpik is offline
Old 29-05-2008, 11:11 PM   #10 (permalink)
Google Bot
Pathik's Avatar
1.2k
Pathik is offline
Old 29-05-2008, 11:39 PM   #11 (permalink)
I found some samsung model on net.........some 22x one @ 1.2k........how is it?????? wil it serve my purpose?????
Sony Vaio CW26FG
Old 11-06-2008, 12:45 PM   #12 (permalink)
sonicspeed's Avatar
sir it is of no use. 16x is the dvd max. speed on dvd. there is not more than this so 16x is a good choice.
Old 11-06-2008, 04:53 PM   #13 (permalink)
smile's Avatar
Smile Re: DVD writer needed
I suggests you to go for Lite-on Dvd writers
SR
smile is offline
Old 11-06-2008, 05:51 PM   #14 (permalink)
15.0 GHz
VarDOS's Avatar
Go For Sony
Or Wait For Some Days And Take A Red Drive
VarDOS is offline
Old 11-06-2008, 08:11 PM   #15 (permalink)
vishald's Avatar
Wink Re: DVD writer needed
Hi never go for Liteon or sony drives. Go for Asus dvd writer. You can check prices at www.deltapage.com
Vishal
vishald is offline
My Writer is not copyin CD/DVD(help needed) tinku dhar Software Q&A 6 02-07-2007 12:13 PM
My Writer is not copyin CD/DVD(help needed) tinku dhar QnA (read only) 2 01-07-2007 08:37 AM
DVD Writer New Needed.. and RAM khandu Hardware Q&A 16 07-02-2007 03:24 PM
dvd writer probs help needed Siriusblack Hardware Q&A 1 11-01-2007 10:12 AM
DVD Writer needed!! harmik Hardware Q&A 15 10-12-2006 12:53 AM
