Old 27-05-2008, 04:11 PM   #1 (permalink)
Default 8800GT query
hello all. i recently bought 8800GT of gigabyte and it has come with the power cable.
my query is i plugged the black end part into the card while other side has two white power
sockets.
should i plug two power plugs from smps into the other sides or just one slot?
thanking you all.
Digital_Paladin_ is offline
Old 27-05-2008, 06:17 PM   #2 (permalink)
sonicspeed's Avatar
Default Re: 8800GT query
I think u are talking about this cable
sir u should plug both connectors to molex connectors and the black one to 8800gt.
sonicspeed is offline
Old 27-05-2008, 06:18 PM   #3 (permalink)
Ethan_Hunt's Avatar
I assume you are talking about the 6-pin PCI-E converter cable.It should be the splitter cable which you must have connected.The white part(molex connectors) are split into 2.These cable should be connected to any 2 free power connectors on your PSU.I had got the exact same doubt which I got clarified from TE forums.What's the brand of your PSU? Doesn't it have a 6-pin PCI-E connector? Make sure you check & see if it had enough power to run this card.
V for Vendetta
Ethan_Hunt is offline
Old 27-05-2008, 09:54 PM   #4 (permalink)
true. to run that card , u'll need atleast a cooler master 600W , and these psu's come with a 6 pin pcie connector ( the black one that u're suppose to connect to the g-card ). . so no need for converter. . .only if u're psu doesnt have a 6 pin pcie connector , then u'll need to use the converter. . what psu do u have ?
sagargv is offline
Old 27-05-2008, 11:28 PM   #5 (permalink)
thank you for answers. yes i have zebronics 400W SMPS and i had just plugged the
one white connector to PSU power supply. i was in dilema that i have to connect the
both or just only one.
i have plugged the black part onto the g-card ( Gigabyte turboforce NX88HP something.
so i guess i will have to upgrade to 600W smps.
Guys is the VIP SMPS good ones?
Also the molex connectors from my PSU have 4 wires to it and the g-card has three cables
to it. is that any different?
If possible please upload the picture of 8800GT connected to pc with power supply.
Old 28-05-2008, 12:20 AM   #6 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
let me guess: you have the Zeberonics 400W PSU that you got most sarcastically indeed with the Zeberonics Gaming Cabinets series ? Its not at all enough, and zeberonics should get their a$$ kicked for providing such a low power Power Supply on a cabinet designed for gaming.
VIP SMPS is good(so is VIP underwear). Get a 600 watt PSU to enable running an 8800GT card.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 28-05-2008, 12:27 AM   #7 (permalink)
We Both Have a Mouse!!!
nishantv2003's Avatar
C2D E6750@3.6GHz - XFX 650i Ultra - XFX 8600GT - 2x1 2GB 800MHz JetRam - CoolerMaster eXtreme Power Duo 600W - 750GB HDD - LiteOn LightScribe DVD RW -
HP W1907 19" Wide...
and Altec Lansing ATP3...
nishantv2003 is offline
Old 28-05-2008, 08:54 AM   #8 (permalink)
get alteast a cooler master 600W ( or 500W ) - 3.2k
sagargv is offline
Old 28-05-2008, 10:46 AM   #9 (permalink)
Ethan_Hunt's Avatar
Just as I thought.Before you end up frying your new card it's better to get a good rated PSU.Like other's recommended,a Coolermaster Extreme 600W would be more than enough to handle this card.Don't even think of risking it with the default 400W Zebronics PSU.Heck I didn't risk my 7900GT with it & went ahead with a Powersafe 500W instead.Get the PSU upgraded & it would have a direct 6-pin PCI-E connector which will directly go from the PSU to you card's slot.No need of that converter.
V for Vendetta
which 8800gt to buy and which psu would b decent? official Hardware Q&A 6 26-04-2008 11:05 AM
Which Brand To Go For 8800gt amrawtanshx QnA (read only) 3 21-04-2008 01:09 PM
rig on which 8800gt will not bottleneck !! allmighty Hardware Q&A 4 19-12-2007 06:42 PM
8800GT in the house .... deathvirus_me Hardware Q&A 31 24-11-2007 11:39 PM
