Old 27-05-2008, 12:09 PM   #1 (permalink)
Default 22" or 24" wide lcd
1. Is 24" monitor with 1920 x 1200 Resolution really worth as its price increase a lot from 22" 1680 x 1050 and are there much hd videos available in india?
2.what is the difference between tft and lcd panels and which is better and cheaper ?
kuki_295 is offline
Old 28-05-2008, 02:29 AM   #2 (permalink)
Point Blanc
Default Re: 22" or 24" wide lcd
Few of good results from googling
TFT-LCD
Little INFO
Little
And again copy paste
Old laptops used to have one of the 2 different technologies: passive screen or active screen (TFT). The difference was that active screens could handle quick updates of the screen while passive couldn't. That means a passive screen was far less luminous (but cheaper and use much less energy) but was enough for office use, but forget about games and movies...instead, the TFT was made for those applications that updated the screen very quickly.
The higher the screen size the better it is, but its good only if the res is also better, and the features provided in the monitor is considerable.
you need to check the specs also and not just the size.
acewin is offline
Old 28-05-2008, 10:23 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
First of all, Do you have the Graphics card and CPU that can drive a 22" or 24" display??
Since the price difference between 22" and 24" is very less and that 24" supports FullHD and 22" doesn't, it's better to for for 24" or else you can stick to 20"
desiibond is offline
Old 28-05-2008, 11:09 AM   #4 (permalink)
ArZuNeOs's Avatar
Mr Bond ,cant the onboard chipset AMD 780G of ASUS M3A handle a 24 incher...
Back to the world of realms
ArZuNeOs is offline
Old 28-05-2008, 11:26 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
ah. okay. yes it will support but you can't play games at full resolution. watching HD moves etc should be smooth
Old 28-05-2008, 04:19 PM   #6 (permalink)
Well here's few specs of lg and dell
Lg Model : L226WTQ & L246WP
Size 22" - 24"
reso 1680x1050 - 1920x1200
bright 300nits - 500nits
response time 2(GTG) - 8(GTG)
view angle 170 - 178
contrast ratio 5000:1(DFC) - 1000:1
power consu 45watts - 80 watts
price 14700 - 24700
Dell DellTM SP2208WFP 22 & DellTM E248WFP 24
Size 22" - 24"
bright 300cd/m2 - 400cd/m2
response time 2(GTG) - 5
view angle 160 - 160
contrast ratio 2000:1 (Dynamic)typical - 1000:1 typical
price 16500 - 19200
22"Interface
High Definition Multimedia Interface (HDMI)
Digital Visual Interface - D (DVI-D) with High Definition Content Protection (HDCP)
Video Graphics Array (VGA)
HDMI 2.1 Audio Out
1 USB 2.0 upstream port
4 USB 2.0 downstream ports
DC power connector for Dell Soundbar
AC power cord connector
24"
Interface
Digital Visual Interface - Digital (DVI-D) with High Definition Content Protection (HDCP)
Lg has a huge price diff is it worth it?
Well now can someone suggest me a monitor below 20k 22" or 24" which ever is better
and how to buy a dell monitor? i live in kota(rajasthan)
kuki_295 is offline
Microsoft "new" patent could "force" downloaders to view commercials!! Hitboxx Technology News 17 28-12-2007 09:06 PM
NEW VIRUS GIVING MESSAGE:"Can not find script file"WIN32.DLL.dll.vbs" ". mdp Software Q&A 5 02-10-2007 02:11 PM
help! in buying19" wide lcd sourav TVs / Monitors 4 09-09-2007 09:09 PM
17" wide lcd driver? mr_brij Software Q&A 3 10-07-2007 12:19 AM
VISTA TUTORIAL: Add "Hide File Names" Option in "View" Menu of Folders Vishal Gupta Tutorials 7 27-06-2007 10:46 PM
