Old 26-05-2008, 01:18 PM   #1 (permalink)
bajaj151's Avatar
Default Ups ? Va ?
Config:
Mobo: Intel 915
Processor: P4 3.0Ghz HT
HDD: Seagate 320 GB SATA
Ram: 1 GB Transcend
Graphics Card: Nvidia 7300
DVD-W: Liteon
Cabinet: Zebronics Antibiotic ( 3*80mm fans + 1*120mm fan) with 450 Watts
Monitor: Samsung 17" CRT
TV Tuner: Pinnacle 110i
LAN Cards: 2
Mouse+ Keyborad
Future possible upgrades: 9 Series Graphics Card
22" Widescreen LCD
Extra 1 GB RAM
Connect 5.1 Speakers (Not confirmed)
How much VA required for my config for atleast 15 min backup ?
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now
Old 26-05-2008, 01:38 PM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: Ups ? Va ?
get a APC 650VA for 3k.u'll get 15mins of backup and peace of mind.
hellgate is offline
Old 26-05-2008, 02:07 PM   #3 (permalink)
GaurishSharma.com
gary4gar's Avatar
APC Ups nowerdays are not good.
Recently Replaced my friends APC UPS within 3months of purchase.
But yes, their warranty service is good
gary4gar is offline
Old 26-05-2008, 04:31 PM   #4 (permalink)
bajaj151's Avatar
How much 1KVA cost me ?...Is it worth buying ?
Old 26-05-2008, 05:43 PM   #5 (permalink)
At Hell's Disq
hellgate's Avatar
APC 1.1kVA will cost bout 7.5k.better get a Powercom 1kVA ups for 5.8k.gives bout 20 mins of backup with my rig and also has option of adding xternal battery.using it 4 the past 5 months.not a single prob till now.
hellgate is offline
Old 26-05-2008, 10:06 PM   #6 (permalink)
bajaj151's Avatar
I think...its better to go for Inverter which cost me arnd 12k..whts ur suggestion ?
Old 26-05-2008, 10:19 PM   #7 (permalink)
Point Blanc
right a digital power invertor is what you would wanna buy spending a little more, but that is why dominator suggested 650VA UPS.
acewin is offline
Old 26-05-2008, 11:04 PM   #8 (permalink)
At Hell's Disq
hellgate's Avatar
if u hav the money then its surely better.also remember that u hav to spend xtra 6-8k to buy battery for that inverter.
hellgate is offline
Old 27-05-2008, 12:00 AM   #9 (permalink)
bajaj151's Avatar
U mean to say... 12K +...extra 6k ???
Old 27-05-2008, 06:36 AM   #10 (permalink)
priyadarshi
Posts: n/a
Current Config:
UPS: APC BACK-UPS ES 500VA
Mobo: Intel DG965RY
Processor: P4 E4600 Core2Duo 2.4Ghz
HDD: Seagate 500 GB SATA
HDD: Seagate 250 GB SATA
Ram: 2X1GB DDR2 Transcend 667Mhz
DVD-W: Sony SATA
DVD-W: Sony PATA
Cabinet: Navtech Normal ( 2X80mm fans)
PSU: eXtreme Power Plus 460W (RS-460-PCAR-A3)
Monitor: LG 17" CRT
PCI USB Card
TVS PS2 Keyboard
Logitech USB Wireless Mouse
19" Widescreen LCD
Graphics Card: Nvidia (Model not sure) for better movie experience not for gaming purpose
Extra RAM: 2X1GB DDR2 Transcend 667Mhz
Please suggest me the best UPS for my config.
Old 27-05-2008, 06:47 AM   #11 (permalink)
What's VA?
manasgta is offline
Old 27-05-2008, 10:18 AM   #12 (permalink)
I Always Prefer 1080p
techtronic's Avatar
1 VA (UPS) = 0.6 Watts (SMPS)
Use the PSU Calculator to decide what PSU you want.
Depending on that buy UPS.
PSU Calculator : http://www.extreme.outervision.com/powercalc.jsp
techtronic is offline
Old 27-05-2008, 10:49 AM   #13 (permalink)
At Hell's Disq
hellgate's Avatar
yup thats true.
cheap inverters do not provide a stable pwr output reqd for running pcs.so to run pcs u need to get a good quality pure sine wave inverter whihc costa anything between 9-15k depending on VA.next u need to purchase battery whihc depends on how much backup u want.the more backup u want the more u hafta spend on battery.
hellgate is offline
Old 27-05-2008, 03:00 PM   #14 (permalink)
bajaj151's Avatar
yup thats true.
Thanks bro...
