Old 26-05-2008, 12:29 PM   #1 (permalink)
ankitsagwekar
Posts: n/a
Question Going to buy amd 5600+ help
I m plan to buy amd 5600+ 780g chipset mobo
Now I m confuse when I go to amd site the clock speed and architecture is different
I see amd site 5600+ is 65nm with 95tdp but when I go thitwares.com & primeabgb they show different clock rate and 90nm processor
Can I get 65nm base processor in Mumbai ?
Old 26-05-2008, 12:42 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Going to buy amd 5600+ help
It is 65nm only. 90nms arent available anymore.
Pathik is offline
Old 26-05-2008, 12:50 PM   #3 (permalink)
ankitsagwekar
Posts: n/a
is this writen in box pack?
how i know it is 65nm or 90nm while buying
Old 26-05-2008, 01:12 PM   #4 (permalink)
ArZuNeOs's Avatar
Look at the box ....Caption says " Energy Efficient "
Also its bar code reads ADO5600IAA6DO ---AMD Athlon™ X2 Dual-Core 65 W
This is the model u are looking for ...check with the AMD Website for more details [Box code]
Back to the world of realms
ArZuNeOs is offline
Old 26-05-2008, 01:39 PM   #5 (permalink)
ankitsagwekar
Posts: n/a
thanks ArZuNeOs
my last query
it's true ?
i get 65nm processor normaly or i get fool by shopkeeper
i m going to buy it from laminton roan mumbai
Old 26-05-2008, 01:45 PM   #6 (permalink)
At Hell's Disq
hellgate's Avatar
just check the product completely b4 u buy it.u wont get cheated.just dont blindly believe wat the vendor says, do ur homework then buy.
BTW why r u investing so much to buy AMD when u can get E7200 + abit IP35-E for the same price?
hellgate is offline
Old 26-05-2008, 01:52 PM   #7 (permalink)
ankitsagwekar
Posts: n/a
amd 5600+ = 5500
780g + HD 3200igp +dx10 + pci-e 2.0 hdmi =4800
=>10000k
intel 7200 = 6000
p35 = 5000 + 8600gs = 2500
=< 13500
what u say about this ??
Old 26-05-2008, 01:57 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
8600gs?? That's a really sutpid card. 8600GT is better.
I would go with the Intel config
1) E7200 : 6k
2) Abit IP35E : 5k
3) MSI NX8600GT 256MB : Rs.4.5k
Rs.15.5 in all and will be a damn good gaming config (not for hardcore gaming though)
desiibond is offline
Old 26-05-2008, 02:00 PM   #9 (permalink)
At Hell's Disq
hellgate's Avatar
and that procy can be oc'd to gr8 levels.also its 45nm.
hellgate is offline
Old 26-05-2008, 02:17 PM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
After lot of discussions and reviews on the forum, I would say
1) If you have money to spend, don't look back. get Intel config
2) If you are on a tight budget, don't look ahead. Get AMD config.
Old 26-05-2008, 04:05 PM   #11 (permalink)
I M A *STAR*
saqib_khan's Avatar
If u want the best IGP go for AMD platform.
Blogging at:
Technostarry
saqib_khan is offline
e6750 or X2 5600+ The Day Walker! Hardware Q&A 42 19-09-2007 10:54 AM
Suggest motherboard for AMD X2 5600+ premsharma Hardware Q&A 29 18-05-2007 06:59 PM
Windows Vista 5600 Release Candidate 1 (RC 1) - A Technical Preview qudra Software Q&A 4 10-09-2006 03:45 PM
NEWS: Windows Vista RC1 build 5600 Released ! Vishal Gupta Technology News 8 03-09-2006 05:40 PM
Radeon 9600 Pro Vs. Fx 5600 mad_gundam Graphic cards 6 17-08-2004 06:35 PM
