Old 26-05-2008, 12:09 AM   #1 (permalink)
Unhappy Hard disk is not getting detected some time after booting
I am facing a strange problem of my second HDD which is 160GB PATA, getting undetected by my computer after I successfully boot it. I am using Asus M2A-VM motherboard. I first thought that the problem may be with my data cable.So I changed it. But this problem reappeared after some days. Even DVD-Writer is also getting this problem. My first HDD which is 160GB SATA is not showing this problem.
Some times this problem appears even after 2-3 hours of use and sometimes just after the computer boots completes. Even the BISO screen does not show HDD. I need to remove all the power and data cables and reconnect them. Why this may be happening? Is there any problem with motherboard? Please help me.
Anyone who has never made a mistake has never tried anything new
sandeepk is offline
Old 26-05-2008, 12:29 AM   #2 (permalink)
Tech.Masti's Avatar
Default Re: Hard disk is not getting detected some time after booting
try to clear dust on your motherboard
Tech.Masti is offline
Old 26-05-2008, 01:09 AM   #3 (permalink)
The Sorcerer's Avatar
Did you try replacing the sata cable and you a different sata port on the mobo.
Hardware BBQ
The Sorcerer is offline
Old 26-05-2008, 07:44 AM   #4 (permalink)
dhanusaud's Avatar
Follow the instruction as said by Tech.Masti & replace ur IDE data cable.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 26-05-2008, 11:02 AM   #5 (permalink)
I Always Prefer 1080p
techtronic's Avatar
I got BSOD when I use my IDE HDDs on my Gigabyte GA-P35C-DS3R Board.Moment I use my SATA HDDs I get no errors and PC works well.
I do not have any problems with Sony DVD Writer.
When I checked with Gigabyte Website, they had this to say.
http://www.gigabyte.com.tw/Support/M...aspx?FAQID=362
techtronic is offline
Old 26-05-2008, 11:19 AM   #6 (permalink)
At Hell's Disq
hellgate's Avatar
@sandeepk
1st check and see if all jumper setting r correct.also replace IDE cable with a 80 IDE cable.
hellgate is offline
Old 26-05-2008, 11:39 AM   #7 (permalink)
Thanks for you replies. But this motherboard is new. I tried all things such as
1) clean all the dust from inside of the box.
2) change the IDE cable.
3) check for the jumper settings.
But the problem remains. May be the problem is related to some faulty BIOS upgrade. I have 3 months ago upgraded the BIOS.
But everything else is working fine. I will still try to do all the things mentioned here.
But the main problem is the unpredictable occurance of the problem. It may happen anytime. I will try to find the exact way to reproduce the problem. And reply with the result.
One thing I have set the BIOS setting to let SATA drives to be reported as PATA to OS. Does this have anything to do with this?
Thanks again.
sandeepk is offline
Old 26-05-2008, 11:43 AM   #8 (permalink)
At Hell's Disq
hellgate's Avatar
since u suspect that the prob cud be bios related,then either update bios if any update is available or revert back to a older bios version for testing.
hellgate is offline
Old 26-05-2008, 01:17 PM   #9 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
does ur MB support pata drive ? as some dont ......
... W H O T ...
ax3 is offline
Old 26-05-2008, 04:46 PM   #10 (permalink)
Yes my motherboard does support PATA drives. It has a PATA port, hence i could connect my existing PATA drive to it.
sandeepk is offline
Hard Disk makes noise & not detected g_goyal2000 Hardware Q&A 8 25-05-2008 07:44 PM
Hard Disk is not detected in Acronis True Image CadCrazy Software Q&A 6 02-09-2007 10:40 AM
Hard disk not detected in BIOS,earlier worked fine. dabster Hardware Q&A 8 07-06-2007 04:46 PM
booting from external hard disk desijays Hardware Q&A 3 25-11-2006 08:58 AM
Hard disk not detected in BIOS, dabster Hardware Q&A 6 26-09-2006 07:53 PM
